Moving a gas port. How best to plug the old hole?
Results 1 to 11 of 11
    Dec 2008
    Vt USA
    8,915
    1492
    3167
    Default Moving a gas port. How best to plug the old hole?
    I've got a 20 inch , mid length gas port barrel That I would like to convert to rifle length.
    The new hole is easy, the old, now unwanted hole? Hmmm...?
    Obviously an Evil "black gun" application .
    Steel, not SS.
    And on that note, but an aside,
    Has anyone come across a treatise on the subject of gas and bolt TIMING applied to the Stoner design?
    The AK gets by with anything, just throw the metal parts around.
    The Stoner system is more refined. I would like to better appreciate the finer points. Perhaps it is all "trial by Error".
    Jan 2015
    Missouri
    1,350
    224
    861
    Thread it and put a short set screw in it. Make sure it is not extending down far enough to get into the bore
    Don
  3. Likes gappmast, Butch Lambert liked this post
    Dec 2008
    Vt USA
    8,915
    1492
    3167
    Quote Originally Posted by D Nelson View Post
    Don
    I did consider "Spiking the touch hole" i.e. making a hard press plug. the area is exceedingly small. .093
    Mar 2006
    New Jersey
    1,184
    17
    374
    You can thread it for a set screw with a little teat machined on the end. Make the teat short enough not to intrude into the bore. Any gaps around the teat will be filled and sealed with copper fouling. Use a 6-48 screw and stake around it after tightening it, as Loctite's will not hold up to the barrel heat.
  6. Likes Kurt Learning, Butch Lambert liked this post
  7. #5
    May 2017
    Minnesota
    1,741
    2255
    1153
    I'm going with chewing gum.
  8. Likes gappmast liked this post
  9. #6
    Sep 2010
    Oklahoma City, OK
    5,407
    1036
    2349
    Pin a collar over it? Like a gas block with no hole.
  10. Likes Archer120x, 1yesca liked this post
  11. #7
    Jul 2018
    Wisconsin
    277
    73
    202
    Quote Originally Posted by MilGunsmith View Post
    This is exactly what I would do. The chewing gum won't hold up.
  12. Likes mhajicek liked this post
  13. #8
    Dec 2008
    Vt USA
    8,915
    1492
    3167
    Quote Originally Posted by Kurt Learning View Post
    Heck! And I made a special trip into town to get a pack of spearmint. I've been chewing on a stick all day to work the sugar out.
  14. Likes Butch Lambert, mhajicek liked this post
  15. #9
    Dec 2008
    Vt USA
    8,915
    1492
    3167
    Somewhat related,
    Has anyone got an idea how Stoner came up with the bolt piston diameter, volume and stroke for the AR-10 and derivatives.?
    There are many variables. I suppose most of the "physics" could be ignored and fall back onto mechanics. i.e. bolt diameter follows cartridge base dia. etc in base terms.
    There are a lot of different events that should follow a logical order and all in a very short period of time. And STILL look at all the variations. Short to long barrels, light to heavy buffers in a variety of lengths, lightened BCG adjustable gas ports. Subsonic to "hot" loads. . I have yet to see aftermarket variable geometry with the bolt piston...
    I suppose some things just can be made to work if the basic design is sound. Tweak here, tweak there.
  16. #10
    Sep 2020
    ALAND ISLANDS
    I would think the reason the aftermarket doesn't mess with bolt piston dia and stoke is because similar results can be achieved by modifying much less expensive parts.
    I would be willing to bet (a very small sum) that Stoner choose the bolt dia based on case head size and then ran experiments to choose gas port location. Also remember that designing a auto for the military is easier on the ammo side as the ammo to be used is a known element, unless your Colt with the original m16 then you test with one ammo and the military field it with another causing all sorts of issues
    Sent from my SM-N960U using Tapatalk
  17. Likes CalG liked this post
  18. #11
    Jun 2004
    493
    390
    61
    no its got to be bazooka joe i like the ring , sleeve , collar but then again how thick is the barrel at that point and if its inside the hand guard who is going to see it [the collar that is]
