Muzzle brake?
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Thread: Muzzle brake?
    Feb 2019
    56
    12
    8
    Default Muzzle brake?
    I have been trying to find a local gunsmith to install a muzzle brake on a Savage model 113 without iron sight. Chambered in .300 win mag, so I need some help with recoil and muzzle raising, so this is necessary for the upcoming hunting season.
    I have toyed with the thought of making my own brake and have it installed, any reason not to use aluminum for a stainless barrel? I have a machine shop and have some ideas for the design that I have not seen in after market offerings.
    Thanks!
    Aug 2012
    Humble, tax
    Quote Originally Posted by Mold God View Post
    Thanks!
    Galling, high differences in thermal expansion, and gas cutting. For a short trial it might be OK.
    Aug 2015
    Illinois
    1,423
    1015
    619
    You are a machinist, right? If you can make your own muzzle brake you are certainly able to thread the barrel. You don't necessarily have to remove the barrel from the action to thread it. On a Mauser I held the action in a 4 jaw. I used a barrel protector on my live center.
  4. Likes jonok liked this post
    Feb 2019
    56
    12
    8
    Okay, no aluminum for the brake. Although it is a hunting rifle, one or two shots while in use, and a few more for zeroing the scope. Galling would not likely be a problem.
    I am not comfortable with spinning all of the stuff around in a lathe, I would expect to take the barrel out. This is not my cup of tea and would much rather pay someone who does this sort of thing all the time. I get paid to do things my customers understand but do not have the experience or talent to do. Yes, I have the talent, but I can make more money doing my job than it will cost to have the job done well by an experienced gunsmith.
    Apr 2008
    West Coast
    289
    58
    53
    I am in Oakhurst CA. I am also a factory installer for KDF. Best brake you can put on a hunting rig. If we are not close to each other, the Brown Truck comes here every day.
  7. Likes michiganbuck liked this post
  8. #6
    Nov 2012
    Michigan
    603
    195
    176
    Okay, no aluminum for the brake. Although it is a hunting rifle, one or two shots while in use, and a few more for zeroing the scope. Galling would not likely be a problem...
    Galling is only one issue. IMHO the biggest reason not to use Al for a brake if explosive failure due to grain boundary failure. Practically any flavor of steel will work fine. Galling can be an issue with just about anything on a SS barrel. A heat-proof grease such as molly grease or plumbers grease can help.
  9. #7
    Nov 2006
    Greenwood, Ca
    948
    47
    308
    What is “local” to you? I’m about an hour east of Sacramento.
  10. #8
    Feb 2019
    56
    12
    8
    Quote Originally Posted by 300sniper View Post
    I am in Monrovia, southern Ca.
  11. #9
    Feb 2019
    Massachusetts
    31
    8
    That happens , cant get your free time. I do this also.
    Theres a lot i will do myself matter not the trade. Although now im older and saving time is more important than money.
  12. #10
    Dec 2017
    Idaho
    369
    104
    87
    Aluminum brakes have been used successfully on large calibers (300wm, 30stw, etc) for thousands of rounds. Aluminum worked great. Not sure why people say they don’t work.
    Avoid radial brakes if you hunt off bipod unless you enjoy a large dust cloud around you.
  13. #11
    Nov 2012
    Michigan
    603
    195
    176
    Quote Originally Posted by Mram10 View Post
    Aluminum scuba cylinders have been used successfully for more than 50 years too... However, occasionally they fail with catastrophic results EVEN AFTER annual visual and 5 year interval hydostatic testing. . Grain-boundry creep is real and makes Al a poor choice for products with high pressure high / impact loading.
    Other than that... Al will work in a muzzle brake... Until it doesn't!
  14. Likes garyphansen, Butch Lambert liked this post
  15. #12
    Dec 2017
    Idaho
    369
    104
    87
    Quote Originally Posted by MIBill View Post
    How much pressure are you expecting at the muzzle that 6061 can’t handle? On a 26” barrel, most magnums are under 1000psi at the muzzle with a 26” barrel. Hardly anything.
    Have you actually tested an aluminum brake? We have and can tell you from experience, they work with 300wm, 30-338, 338 edge and 30stw for over 1000 rounds.
  16. #13
    Oct 2002
    Poetry Texas USA
    1,791
    338
    233
    Here we go again!
  17. #14
    Feb 2001
    Arizona
    2,217
    350
    So how much flame cutting/erosion do you see after 1000 rounds?
  18. #15
    Dec 2017
    Idaho
    369
    104
    87
    Quote Originally Posted by Butch Lambert View Post
    Here we go again!
    What did I say that was wrong? I’ll defer to you on wind flags, since I have no experience. How many aluminum brakes have you made or tested?
    Sorry I’m inserting actual experience into the forum. I honestly don’t care what you think. I only give input when I KNOW something based on experience.
  19. #16
    Dec 2017
    Idaho
    369
    104
    87
    Quote Originally Posted by GGaskill View Post
    So how much flame cutting/erosion to you see after 1000 rounds?
    We didn’t run any measurements or tests other than functionality and eye test. Shot the same, didn’t loosen and looked normal.
  20. #17
    Nov 2004
    RC, CA
    1,974
    211
    376
    Curious where you got the 1000 psi number. I've heard estimates of 5 to 10x that. An article I pulled up shows measurements of near 5k for a 223 in a 24" barrel.
  21. Likes Butch Lambert liked this post
  22. #18
    Nov 2012
    Michigan
    603
    195
    176
    Here we go again!
    LOL... Sorry but I'm NOT going to go down the rabbit hole AGAIN. I have a crap load of experience testing and inspecting Al pressure vessels. Mag flux, x-ray, ultrasonic and mechanical as well as visual... I am also VERY familiar with Hydro-static testing procedures. I think we have also established that I know a thing or two about muzzle brakes...
    I know what I know and have the experience to back it up!
    No actual testing??? Visual inspection only??? What experience / training does this inspector have??? Does this "inspector(s) know what grain boundary creep is??? Since fracture in Al caused by grain boundary creep is rarely visible to the unaided eye... I just hope your liability insurance is paid up!!! I know from actual testing, training & experience that you are headed for a catastrophic failure and a huge judgment. It is more likely a question of WHEN than IF.
    If you choose not to believe me, it's your loose not mine!
  23. Likes MetalCarnage, Butch Lambert liked this post
  24. #19
    Dec 2017
    Idaho
    369
    104
    87
    Come back when you have tested an aluminum brake and post your EXPERIENCE rather than an opinion.
    The 1k is based on another’s research of a 26” barrel (300wm and 300 wby)
    Bullet Ballistics 101: Pressure, Velocity & Distance
  25. #20
    Apr 2014
    803
    1013
    535
    If the pressure is so low at the muzzle, how is the brake going to be effective? Or is it just a placebo? I'm reading articles suggesting that muzzle brakes actually help in long range rifle shooting on the clock. I trust several of the guys in this game. I'm confident that an aluminum brake on those rifles (6mm Creedmoor, 6.5 Creedmoor, , souped up .243's, etc) would fail.
    I have used and made many brakes, mostly handgun - round count is higher than most long guns. There is no way I would install an aluminum brake on my personal rifle. There is wide variety in pressure at muzzle. Barrel length, powder burn rate, initial chamber pressure, and other factors can make a rather large difference in pressure at muzzle. I've seen brakes fail, and those that don't. I'd suggest StressProof, or something even better.
    Just my opinion, based on my personal experience.
    YMMV.......
  26. Likes Lharmon, Butch Lambert, MetalCarnage liked this post
