Muzzle brake? - Page 2
Results 21 to 40 of 52
Thread: Muzzle brake?
  1. #21
    Oct 2002
    Poetry Texas USA
    1,911
    570
    280
    Quote Originally Posted by Mram10 View Post
    Come back when you have tested an aluminum brake and post your EXPERIENCE rather than an opinion.
    The 1k is based on another’s research of a 26” barrel (300wm and 300 wby)
    Bullet Ballistics 101: Pressure, Velocity & Distance
    As I've said above and in the other forums that you spew "knowledge", You are out of knowledge of which you post. I'm not a brake person, but I defer to MlBill and others that have been in the field for many years. Your posts on the various forums shows your knowledge must be true as you "think" you read it on the INNER NET.
  2. #22
    Sep 2010
    moscow,ohio
    6,386
    651
    2128
    if you test one please be sure to install it on a stainless barrell.
  3. Likes Butch Lambert liked this post
  4. #23
    Jun 2012
    Michigan
    12,132
    4097
    4348
    Agree if you are not 100% comfortable let a good gun smith do the job. I would have it made in SS.
  5. Likes Butch Lambert liked this post
  6. #24
    Feb 2019
    Massachusetts
    36
    8
    I,have quick loads program that gives pressure from chamber to muzzle.
    Give me some rifle data and load data and I will enter it and see what spits out.
    I cant seem to get screen shots to work but I ran data for my M1a and my 168gn bullet and 41.5 grains of H4895
    I got 8000psi at the muzzle?
  7. Likes Butch Lambert, eaglemike liked this post
  8. #25
    Apr 2014
    928
    1179
    622
    Quote Originally Posted by mac1911 View Post
    I've seen "tanker" M1a's too - just for fun, want to check a 16" barrel? Temperature would make a bit of a difference if one was using aluminum for a brake. There's more than a few bolt guns that would run higher pressures (and temperatures!) than your M1a. Barrel life for a standard M1a load is a fair bit longer than some of the barrel burners out there.
    BTW, how do you like using quick load? I've had to do some work ups in the past, and modern technology would have made the process far shorter.
  9. #26
    Mar 2006
    New Jersey
    1,138
    13
    341
    I build pressure test barrels every day. On a 20" barrel in 5.56mm the port pressure at 4.5" from the muzzle is in the 10000psi range,from 60000psi at chamber. I can't see pressure dropping to 1000psi in another 4" .
  10. #27
    Nov 2012
    Michigan
    615
    205
    184
    Quote Originally Posted by eaglemike View Post
    If the pressure is so low at the muzzle, how is the brake going to be effective? Or is it just a placebo?
    Pressure at muzzle would have zero effect on whether or not a brake would perform well. It is ALL about the velocity and mass of the gasses and how well the brake is able to capture that energy. After the bullet passes the out of the first port, it would be this same force that would be acting on all parts of the brake. It is not the same "pressure" that one would measure with sensors or strain gauges on the barrel, but rather the force of the gases(inertia) striking the rearward facing surfaces.
    There is no way I would install an aluminum brake on my personal rifle.
    Smart man!
    There is wide variety in pressure at muzzle. Barrel length, powder burn rate, initial chamber pressure, and other factors can make a rather large difference in pressure at muzzle. I've seen brakes fail, and those that don't. I'd suggest StressProof, or something even better.
    Just my opinion, based on my personal experience.
    YMMV.......
    Although there is no reason why "stress proof" steel could not be used, there is no real advantage over 4140 or 416. In most cases I prefer to make brakes out of the same material as the barrel it is going on... Unless it is going on a sleeved Al or composite wound barrel.
  11. Likes Casady Machine liked this post
  12. #28
    Dec 2017
    Idaho
    369
    104
    87
    Compare the tensile and yield psi of 6061-6 v 304 stainless.
    6061t6 is 45k and 40k
    304ss is 73k and 31k.
    The 6061 has a better yield strength. Not difficult to handle the psi at the muzzle of a standard length barrel. We used 26-30” depending. They were 1” brakes, drilled .02-.03” over bore. These were heavy hitters not 6.5cm or 243.
    Wouldn’t Try it on a 338Lapua with a 16” barrel.
  13. #29
    Dec 2017
    Idaho
    369
    104
    87
    Quote Originally Posted by Butch Lambert View Post
    What knowledge am I spewing?
    6061 specs are easy to find. Any metallurgist will tell you yield values are the more important when constructing something like this.
    Pressure values at the muzzle for a 26” barrel are under 10k, easily. Didn’t make that up.
    Butch, you love to give me a bad time anytime I post. I’m flattered but maybe you should try it before you disagree or defer to milbil. Again, I’m sure you know wind flags better than I do, so I’ll happily defer to you on that
  14. #30
    Apr 2014
    928
    1179
    622
    Quote Originally Posted by MIBill View Post
    Smart man!
    Stressproof has nice mechanical properties, and machines (and finishes) very nicely. Not everyone knows how easy it is to machine. I've also machined a fair amount of 416, as it's my choice for a free machining stainless.
  15. #31
    Apr 2014
    928
    1179
    622
    You keep bringing up 304. I've not heard of any positive expressions here about machining 304. It's my opinion you are not making a solid, principled argument for your choice of material, using 304 for comparison. If you personally want to use 6061 for your brakes, it's your choice.
    If you were going to choose a better material like 416, or 17-4, that would be a more valid comparison. These materials machine reasonably, obviously not the same as 6061 though.
  16. #32
    Dec 2017
    Idaho
    369
    104
    87
    I use 304 as an example because many brakes are made from it. Use what you want, but 304 works great, thus a good comparison for the 6061.
  17. #33
    Nov 2012
    Michigan
    615
    205
    184
    The numbers for 6061t6 Mram10 cited are crap to start with... Although it is TRUE that typical vales are close to what he cited, ONLY MINIMUM values are specified for 6061t6. ONLY these MINIMUM values should be used unless you have the facilities to test tensile and yield strength. The CORRECT values are: tensile 42,000 psi yield 35,000 psi. HOWEVER, the fatigue limit is only 14,000 psi. STRIKE ONE!
    Next 6061t6 Is NOT even the best choice of readily available aluminum alloys for this type of application... 7075-t6, 7075t651, 7075t7 or 7075RRA would be better choices. Each of these heat treats would be slightly better than the one before it. However, only the t6 is readily available (check McMaster-Carr). STRIKE TWO.
    And none of this takes into account aluminum's nasty habit of developing stress fractures. Please google Fatigue limit. STRIKE THREE!!!
    He clearly does NOT understand the nature of the materials he is working with! I believe this is what Butch is referring to when he used the expression "spewing knowledge". Mram10's "knowledge" is incomplete and dangerously lacking. Some times a little knowledge is worse than none at all...
  18. #34
    Feb 2019
    Massachusetts
    36
    8
    I bought it through a group buy on M14forums saved a few bucks.
    i like it. Im still trying to figure out the ins and outs. Its come in handy though for looking at different powders and bullet combo and seeing a close out come of the internal balistics. Been using it for looking at different cast loads, which im finding is darn near spot on for velocities. Thats what Im looking for.
    The application seems way to involved for my simple needs but getting to the range , setting up crony only to see im not where I need to be is frustrating.
    Theres not a lot of cast load data out there. Especially for semi auto rifles and more modern stuff.
    I run cast in many rifles in 200 yard matches.
    I will be playing around with cast loads for the M1a soon
  19. #35
    Feb 2019
    Massachusetts
    36
    8
    not sure what your looking for
    M1a 16" barrel 7.62 NATO M80 ball ammo shows 11,830psi at the muzzle
  20. #36
    Feb 2019
    Massachusetts
    36
    8
  21. #37
    Mar 2006
    PHILIPPINES
    2,813
    829
    1204
    So many professionals giving the numbers for pressures but yet forgot something most of us where taught in 6th grade science class. Bimetallic (Galvanic) corrosion. The OP said a Stainless barrel with an Aluminum muzzle break. Aluminum is Anodic to stainless and begins corrosion at first contact. So basically the threads on both the barrel and the break will eventually dissolve. So, how do the pressure numbers work with thread decay?
  22. Likes Casady Machine, Mold God liked this post
  23. #38
    Sep 2010
    moscow,ohio
    6,386
    651
    2128
    ^^^ ding!ding!
    winner,winner! chicken dinner!
  24. #39
    Apr 2014
    928
    1179
    622
    Thanks very much for your reply. Someone above was saying that pressure was down to 1K or so at the muzzle. If some manufactures a brake(s), unless it's custom, it's likely not know what the actual pressure/temperature/etc will be. My point was that I (at least) would not assume a brake would be installed in a 1K environment. As many others have noted, 6061 is just a poor choice (IMHO) if I want it to live for more than a few shots. I wouldn't even bother to build one for testing on a firearm, might use to proof a program.
    Material cost is not much, and machining time difference isn't a huge part of the cost either, comparing 6061 to 416. Raise the price by $10 to $40 to account to increased costs over 6061,and sell a far superior product. That's how I'd look at it, anyway. YMMV, of course.
  25. #40
    Sep 2010
    moscow,ohio
    6,386
    651
    2128
    snip// 4140 or 416. In most cases I prefer to make brakes out of the same material as the barrel it is going on.
    good advice here...and also gcoders comment on galvanic corrosion...which should be a serious consideration...not to mention the added effect of the byproducts of combustion...it's a recipe for failure...today,tomorrow,10yrs...I know I don't want to be there.
