New 07 Smith Machine Tooling Help
Likes Likes:  0
Results 1 to 6 of 6
    Jul 2016
    Illinois
    Default New 07 Smith Machine Tooling Help
    Hi Folks-
    I am new to manufacturing, having worked on guns for years and years, I finally decided to up it a notch and get my 07 license this month.
    I would appreciate some direction into a CNC late and laser engraver machine, nothing high end commercial at this point, but more entry level. Second hand is welcome as well. I already work with a mill/drill/lathe combination which is good for small stuff and barrels, receivers, etc. albeit much more manual and slower. Since I am manufacturing, I would like to go to something I can manage both aluminum and steel for manufacturing receivers for both modern sporting rifles and bolt actions. I'd like to be able to thread as well. Either or both need to be able to do ATF compliant engraving at .003" deep by 1/16" or larger print.
    I've taken interest in the APSX Spider machine here [ Tabletop Metal CNC Milling Machine Affordable CNC Prototyping ] as an entry level CNC machine. I also found Trotec lasers for engraving, but I think they are too advanced for me at this point. If the CNC can do the ATF compliant engraving, the laser will only need to etch anodizing or light etching on metal work.
    Currently, my initial production will be less than 24 a year as I have a full time gig on top of this and intend on quality over quantity initially. As far as the space requirements, both machines need to stay close to a footprint [not working footprint] of 48 by 36 but I have some negotiating room. I have compressed air and ventilation available already, Its just a really small space to start working in.
    Thanks for your help.
    GodSpeed.
    May 2018
    Ohio
    Have you had a cnc machine yet?
    May 2004
    Zellwood, Fl.
    1,443
    605
    281
    For the cost of a laser you can buy a Tormach. Plus if the tube goes on a laser think 1.5k to 3k for replacements. Do you know CNC any experience with that. The learning curve on a 3 axis machine is relatively low with the software. A Bit of CAD experience would help too.
    Jan 2015
    Missouri
    893
    207
    541
    The laser shines on uneven surfaces where a mill has troubles engraving
    Dec 2017
    Idaho
    325
    90
    59
    Have you considered electro etching since your volume is low?
    Nov 2007
    marysville ohio
    9,108
    2588
    6015
    Quote Originally Posted by CedarGrove357 View Post
    Hi Folks-
    GodSpeed.
    Are you going to actually try to make a receiver on that thing? if you are just going to engrave with it I can see that working ok. as far as doing real machine work, moving metal in any quantity forget it, it's a toy.
