Nickle Plating - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Nickle Plating
  1. #21
    Nov 2007
    southern michigan
    35
    Quote Originally Posted by MIBill View Post
    Let me START by saying that I do NOT work on firearms belonging to ANYONE else. ANY conductive surface can be plated and plated well... IF one knows how it's done. I usually only do SMALL parts that can be plated with less than a quart of solution. However, A pistol would be VERY doable. Even deep pitting, as long as safety is not an issue, can be covered completely. IF I were to do something like this I would start with a complete disassembly, de-grease and cleaning. I would "fill" any pits using a strike coats of copper sanding and buffing between. Once all evidence of the pitting was gone a light strike coat of copper buffed and a final coat of nickle and it would look as good if not better than new. It is a LOT of time to do it but it is not hard to achieve. Any plater worth his salt could do it. Depending on how much restoration there is to do, the cost could get extreme. DIY could be a better option.
    If you have any questions about DIY plating just ask. It is very easy to do nickle...
    Have several questions perhaps you can answer for me about prep for nickel platting. my 100+ yr. old gun has many dings, scratches, and marks on it. I understand these must be repaired before platting. What is the process used to work the surfaces up to a point satisfactory for platting. How thick will the platting become? any advice would be greatly appreciated.
  2. #22
    Nov 2012
    Michigan
    603
    194
    176
    Quote Originally Posted by dale54 View Post
    The copper strike coat will build about 3-5 thousandths per pass before it starts to get "funky". Clean, buff , clean again, decrease and make the next pass. Masking, sanding and/or buffing is used to fill, mask and feather as needed. Depending on the number of passes and skill, you can build (fill) anywhere between a few microns and a few feet or more... Literally!
    Copper is the electroplater"s Bondo.
  3. Likes NC Rick liked this post
  4. #23
    Nov 2012
    Michigan
    603
    194
    176
    I had looked for these pics when you originally posted this thread and wasn't able to find them.. But there they are now.
    Three steps in the progression...
    Raw... As I got it back from heat treating
    Mid-way through the copper. You can see some of the scratches that are and were filled. It also shows where there was some distortion in the part that I was able to fill and flatten.
    Copper plated and polished
    Nickel plated and polished
    It's just time.
  5. Likes NC Rick liked this post
