Zip
- May 25, 2007
- Champlain, NY
Have a Taurus Tracker 357 and a scope sight base intended for the .17 caliber handgun. The .17 sight base is only held down by one 6-40 screw via the former rear sight stake (and a forward set screw to apply tension)...but I want to use mount on the 357 revolver. What is a suggested number of anchor points required?
I can install another screw thru the top strap 1/2" forward of the existing 6-40 hole and another thru the barrel or top strap above the forcing cone.
Do you think the rear two by themselves is sufficient?
