Pistol Grip shotgun
Likes Likes:  0
Results 1 to 5 of 5
    Jun 2004
    Malta
    RE :Pistol Grip shotgun
    Hello, I am David new one in this forum,
    I need some help I have some shotguns
    And I would like to make a pistol grip
    For my shotgun.
    Some can help me to make this alteration
    To my shotgun.
    Thanks for time
    Regards,
    David
    Jul 2003
    Los Angeles, California
    616
    6
    Many aftermarket, bolt-on options available, check out Brownells. Be aware, if you're in Kalifornia, you might be constructing an assault weapon.
    If you plan to not use a shoulder stock, what I dont like about the typical (near vertical) pistol grip is A LOT of recoil goes right into into your wrist - OUCH! Much better is to just cut off a factory stock just behind the grip, then use some woodworking skills to pretty it up. Your wrist is at a natural angle, and recoil dissipates into your arm rather than stopping at your wrist.
    [This message has been edited by mendoje1 (edited 06-06-2004).]
    Mar 2004
    Edison Washington USA
    10,321
    964
    5322
    Last time I checked, Malta was in the middle of the Mediterranean. Not under the jurisdiction of the California State Government, or even the ATF.
    Also, unfortunately, quite a ways from Brownells. Its a long boat ride from Sicily, much less Montezuma Iowa. UPS would be kinda pricey.
    I think he is looking for do-it-yourself info.
    Jul 2003
    616
    6
    Regarding Malta, I considered that, but decided to leave the response as is (you never know). I offered one DIY solution, plus Brownells or any on-line catalog can be browsed for ideas.
    Here's a good pic of the short grip I mentioned. It's just a shortened factory stock. Definitely DIY material:
    http://www.securityarms.com/20010315...s/0600/665.htm
    And here's a commercially available version (scroll down near the bottom):
    http://www.speedfeedinc.com/frameset_products.html
    Jun 2004
    Malta
    Ok thanks for all help
    I will be back
    Thanks for time
    David
    Good B USA
