Holescreek
Titanium
- Aug 27, 2004
- Centerville,OH
I recently bought a barrel for an H&K G3 type project listed with having a "Match Chamber". When I checked the bullet seating depth to the lands with a 168gr SMK I found that with the bullet touching the lands there wasn't enough left in the case to hold it in place in the cartridge.
In order to see what was going on I cast the match chamber and a standard NATO G3 chamber for comparison.
After taking the diameters I took the casts into work and checked the contours from just behind the shoulder and extended all the way into the land of the rifling to determine where the tallest point of the rifling began.
G3:
Match:
The freebore area of the match chamber is a cone from the end of the neck to the rifling that is longer than anything I've ever seen. Is this something new? I bought the barrel expecting a tight neck diameter and with the expectation of being able to seat the bullet to the lands if need be.
G3:
Match:
