I’ve tried all sorts of “remedies” to solve the chatter problem, carbide, high speed slow feed, slow speed high feed, HSS different profiles, heavy cuts..light cuts, shot bag on the barrel etc.. nothing seemed to work for me, I even considered building a hydraulic follow rest. I make a few barrels in the shop, some with 3 different tapers to them, and I’ve considered getting a tracer attachment for my lathe, but the biggest thing keeping me from do it is controlling the chatter.
What I do now is cut inch by inch coming out of the headstock, then mount the barrel in an old Sheldon lathe with a belt sander mounted on the carriage, a few passes to remove the ridges and barrel looks pretty good.
I suspect that most commercial barrels are ground with something akin to a tool post grinder…just on a much larger scale.
Mike Hunter
www.Hunterrestorations.com
