psi safty question
Likes Likes:  0
Results 1 to 1 of 1
    Mar 2004
    VA, USA
    6
    Im fairly new to machining and im working on an air valve for a paintball marker and want to make it from a 6061 or a 7000 searies alum. Stock valves are made from brass but im trying to take weight off the gun.
    The psi shouldent excied 2000psi but just in case I want it to be able to hold at leaste 2500psi
    Im thinking I can make the walls of the valve aout 1/4" what would the minamum safe thickness of the walls be?
    Should I get it hard coated? Would hard coating strengthin the metal so I can make the walls thinner if needed?
