Re-chamber old 22 single shot .22 for .22 magnum rat shot - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21
    Feb 2003
    Arkansas
    478
    7
    28
    If the old bolt action is a Remington 580, no problem, it will be strong enough. Make up a piloted reamer to remove the rifling.
  2. #22
    Aug 2004
    Virginia
    2,371
    178
    931
    The old rifle I have is a Springfield JR that belonged to my dad when he was a kid. It has some sentimental value but as a firearm it is pretty useless. That is why I considered modifying it to make it more useful. I was not going to remove the rifling. I just assumed it would not matter if it was rifled or not since I will just be using shot. What do you think? Thanks very much for all the useful information.
  3. #23
    Jun 2014
    Floral City, Florida
    26
    9
    Rifling isn't an issue. What is an issue ie whether the chamber can handle the reaming. Depending on which Springfield, it might be fine. Proper measurements will tell you.
    Jeff
    Sent from my XT1254 using Tapatalk
  4. #24
    Aug 2004
    Virginia
    2,371
    178
    931
    weaselfire...without going into great detail, what would I measure?
  5. #25
    Feb 2001
    Arizona
    2,217
    351
    I am not familiar with that model. Rifling causes the shot cup to spin which makes for a really loose pattern. A smooth bore would be better. I do not think drilling out the rifling would be a legal problem as long as the barrel is not shortened too much (like less than the minimum for a shotgun which I think is 18".) But I am not a lawyer.
  6. #26
    Nov 2015
    Oklahoma
    271
    62
    134
    I found this on you tube but didn't watch all of it:
    YouTube
    Might be worth trying a few different brands of shot before you modify your rifle.
    I shot a lot of these shells on the farm. The shot must be extremely soft as I got very heavy lead deposits, enough to really affect the accuracy of regular 22 shells. It would come out in strings around a bore brush. That might not be a problem if rat shot is all you use.
  7. #27
    Mar 2006
    New Jersey
    1,104
    13
    318
    The CCI .22mag shot shells need the rifling to break up the plastic cap. The crimped metal shells and designed for smooth bores.
  8. Likes MetalCarnage liked this post
  9. #28
    Oct 2010
    Dewees Texas
    2,430
    28
    665
    The Wikipedia article on garden guns (Smooth bore) showed a photo of a CCI cartridge. Not sure if the garden guns had a choke, maybe the choke would break the capsule. The 50 foot range and 12 inch pattern mentioned in some of the garden gun articles Is what CrossThread is looking for. From what my experience and what I have read it is not possible with a rifled gun. So it will be a smooth bore and maybe some experimenting with a choke.
    If a one diameter smooth bore did not work well, I think my next step would be to counterbore the end and Loktite a choke in. I would leave a step or thread on the end to pull it out till I found one that I liked, then finish the end with a good looking crown.
    Just a couple of quick notes on shot shells in rifled hand guns.
    7 to 10 feet nice pattern in a Ruger 45 Colt revolver or Bond Snake Slayer.
    So far rattlesnakes stop moving when hit. Ever one of them were killed, prodded them all with a stick to make sure they were dead. Be careful.
    Texas yellow bellied fish snakes will jerk and sometimes come out of the water when hit.
    When CCI 45 Shot shells were unavailable during the ammo shortage a few years ago, Spear capsules were available for reloading. Reloading them is a lot cheaper. If Spear capsules are available in 32 caliber maybe you could load "quiet" ones.
    The 45 shot shell will make your ears ring bad when fired under a shed roof. Gotta be a plus for a 22 garden gun. Even holding the gun out door and sighting through the window on a front porch will deafen you even when pulling the door tight on your arm. Ear muffs protectors are a necessity in buildings are under a roof.
  10. #29
    Aug 2012
    Gurnee ILL. USA
    430
    165
    109
    Get a Winchester model 36 they are THE BOMB for Chipmunks!!!!!
  11. #30
    Oct 2010
    Dewees Texas
    2,430
    28
    665
    When this thread was going I do not remember any late production garden guns. All seemed to be out of production and the few available were going for a premium. Looks like Henry is making new ones in long rifle and 22 mag now. Just saw an article in the local paper that they are available.
    Copied and pasted from the Wilson County News:
    The new Henry Arms lever-action .22 caliber smoothbore “Garden Gun” could well awaken your inner “John Wayne” as you jack the lever, feeding shells from the 15-round magazine as you mow down marauding “varmints” around your garden patch, pilgrim! Care should be exercised with any firearm, but the range of the #12-size shot fired from the Garden Gun is limited. The Henry is a handsome piece and a delight to shoot. MSRP is $421.
    Garden Gun Smoothbore .22 | Henry Repeating Arms
  12. #31
    Dec 2015
    Illinois
    454
    147
    257
    Now you just need to make a thrower for those nasty little NECO Wafer candies and you could shoot mini trap in your shed.
  13. Likes nihilistic, TeachMePlease liked this post
  14. #32
    Oct 2010
    Dewees Texas
    2,430
    28
    665
    Looked on the Henry website and could not find the 22 Mag Garden gun, the local paper's article suggested there was one. Maybe a phone call to Henry is in order to find out. if anyone does that could you ask if these things have a choke.
