Re-contour fluted barrel
Results 1 to 9 of 9
    Mar 2015
    North Carolina
    7
    Default Re-contour fluted barrel
    Has anyone had experience re-contouring a fluted barrel. Hart Barrels said they cannot do it because it breaks their tool bits. I've made interrupted cuts before with very light cuts. Couldn't you do it on a barrel with very slow light cuts with HSS bits?
    Jun 2013
    1,017
    691
    450
    Physics says yes
    economics say no
  3. Likes Lharmon liked this post
    Feb 2001
    Arizona
    2,175
    299
    I saw an ISCAR promotional video a long while back showing their products doing interrupted cuts. Maybe contact them.
    Aug 2012
    Minnesota
    13
    GOOD LUCK tying it on a rifle barrel
    Mar 2010
    Davidson NC USA
    1,400
    502
    788
    Cheaper and easier to start with a new barrel, contour as desired, then flute. Regards, Clark
  7. Likes ernieflash liked this post
  8. #6
    May 2017
    Minnesota
    689
    593
    361
    A four axis VMC with a tailstock would make short work of it. If you have one laying around that is.
  9. #7
    Jan 2009
    Richmond & Davis, Ca.
    30
    When you relieve the stresses by turning off the fluting the bore will warp like a silly straw. It's economically not worth it to try and re-contour a fluted barrel to remove the fluting, but it will also ruin any accuracy potential that the barrel had. Just get a new barrel.
  10. #8
    Mar 2018
    Oregon
    9
    10
    Recontoured a fluted Hart barrel for myself once. Barrel is a tac driver. Light cuts with razor sharp insert worked great.
  11. #9
    Feb 2001
    Arizona
    2,175
    299
    Might be a good idea to make a sleeve that you could slide onto the barrel, true, and let it ride in the steady rest. Unless you remove the fluting entirely, you will have ugly burrs left on the flutes.
