Re-contour fluted barrel
gr71
Mar 30, 2015
Has anyone had experience re-contouring a fluted barrel. Hart Barrels said they cannot do it because it breaks their tool bits. I've made interrupted cuts before with very light cuts. Couldn't you do it on a barrel with very slow light cuts with HSS bits?
I saw an ISCAR promotional video a long while back showing their products doing interrupted cuts. Maybe contact them.
When you relieve the stresses by turning off the fluting the bore will warp like a silly straw. It's economically not worth it to try and re-contour a fluted barrel to remove the fluting, but it will also ruin any accuracy potential that the barrel had. Just get a new barrel.
Recontoured a fluted Hart barrel for myself once. Barrel is a tac driver. Light cuts with razor sharp insert worked great.
Might be a good idea to make a sleeve that you could slide onto the barrel, true, and let it ride in the steady rest. Unless you remove the fluting entirely, you will have ugly burrs left on the flutes.
