Good day
I need some help here.
I have a problem with a new 300wsm reamer.
I chambered a new barrel with this custom fb and nk PTG reamer. The chamber cut with a very nice looking finish and no visible marks. But i have extraction problems after the case has been fired. The brass cases i used, is a new batch of winchester 300wsm brass.
I removed the barrel, cut off the thread and rechambered the barrel again and still have the same problem.
It seems like the reamer might have a high or low spot causing a buldge on the brass. But there is no visible marks on the reamer.
The extraction problems are not extream. There is just some resistance with bolt lift.
I have used ptg reamers in the past and never had problems with them. I sent an email to ptg last week, but they have not responded.
Have any of you had problems like this?
Regards
Konrad
Sent from my SM-G960F using Tapatalk
Regards
Konrad
