Rebarreling of a Mauser C96 Broomhandle. - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
  1. #41
    AVON Guest
    Quote Originally Posted by michiganbuck View Post
    Schlemiel? I had to look that word up
    Resort to name calling...How old are you..thinking now perhaps a teenager.
    Likely your dad being a toolmaker (or the like) could make such a part and assemble it.
    Bieber music mentioned supports that..
    Old enough to have memories of listening to the Del Vikings singing "Come Go With Me" on WTIX AM radio, watching the coverage of JFK's assassination on live TV, upset because it preempted the Lone Ranger, the Beatles playing live in New Orleans City Park Stadium, seeing the 1968 Chicago riots up close and personal, wishing that I was old enough to go to Woodstock. Still think that I'm a teenager? Doctor told me in 2013 I had five years to live, do the math. I'm too stubborn and crotchety to go peacefully into that good night.
    My Grandad was the T&D maker. My other GD was a plant manager in a paint factory. Dad was a tinkerer. Wasn't hardly anything he couldn't fix in a pinch.
    Unlike many, I live life, not just take up space living it. And I have repaired many a gun using hand tools to shape the part needed, polishing them and heat treat them without the use of electric tools. Try it some time, I'm sure that you appreciate your machines far more than you do now.
  2. Likes ramsay1 liked this post
  3. #42
    AVON Guest
    This bickering could go on for a coon's age and I have to go help my son paint an up stairs of a few rooms.
    See Yah..
    Buck
    Paint fumes! That explains much. I need to run as well, hardware store, pharmacy, and flea market. Taking my son with me, he just turned 8yo. Catch me come l8r
  4. #43
    Sep 2010
    moscow,ohio
    6,531
    675
    2267
    BUCK! Clear you mailbox.
  5. #44
    Sep 2018
    Washington
    8
    5
    Not sure what Grizzly combo machine you're looking at but all of the combo machines I've seen run at too high rpm for single point threads.Any decent gunsmith that does rebarreling could do the barrel installation.I would not use a method that requires welding.If you have no experience rebarreling I would not make rebarreling a broomhandle my first attempt.
  6. Likes 72bwhite, N/A liked this post
  7. #45
    Jun 2012
    Michigan
    13,488
    4596
    4866
    Quote Originally Posted by iwananew10K View Post
    OT:
    Message sent, box open space.
    Buck
  8. #46
    AVON Guest
    Tapping and tread cutting I prefer to do by hand. I feel that I have more control that way.
  9. Likes michiganbuck liked this post
  10. #47
    Jun 2012
    Michigan
    13,488
    4596
    4866
    Quote Originally Posted by AVON View Post
    Some times I drill in the drill press with the part fixtured..and then use the drill press chuck, turning tap by hand so the DP becomes a tapping head.
    Used to do a lot of DP, mill and lathe tapping under power but not for gun work.
  11. #48
    Nov 2017
    Kansas
    347
    79
    161
    Who is off topic now? I test my water frequently and the nitrates are creeping up slowly.
  12. #49
    AVON Guest
    Quote Originally Posted by Aejgx6 View Post
    Sounds like fertilizer contamination from Farm runoff. Though, it could be septic as well. Do you have well water or city, town or county water? Do they check the bacteria levels as well?
    Click and read this, Kansas tap water pollution from farm runoff
  13. #50
    AVON Guest
    Quote Originally Posted by Ken T View Post
    Thank you for your insight.
  14. #51
    Aug 2011
    Oregon
    2,686
    635
    825
    I have personal mistrust of this technique. With welding there is always a chance of voids and inclusions that can weaken the joint.
    I watched a video of a P08 restoration in which pitted areas were built up by micro laser welding, it looked like perfect build up beads in rows but done in microscopic size. I was very impressed and have thought a lot about it, like, what does that cost to have done? The Luger showed zero signs of the previous rust.
    I assume the way I'd want to do it would be threaded to a shoulder and then welded by this method to eliminate the shoulder line, seems like it could be done invisibly that way. Glued liner seems cheapo to me, I wouldn't own a gun like that myself, maybe good enough for others though. Threaded to a shoulder even showing the joint would be far better I think.
  15. #52
    Jun 2021
    Indiana
    I would never use Redmans for anything. He is dishonest and will hold your parts for like a ransom. They are not worth it. I had bad experience with them. Never again.
  16. #53
    Jun 2004
    642
    525
    118
    dam i can just barely remember that jfk thing yes there was no cartoons my dad was mad at us for asking about are cartoons
  17. #54
    Jun 2004
    642
    525
    118
    I would like to bounce some ideas off you machinists. I've read the following:
    And I have seen the following listed on Ebay, though it was almost instantly withdrawn by the seller.
    Attachment 252507
    So, the questions that comes to mind are, if one had a beat German Mauser C96 upper, formerly owned by the Chinese, would it be feasible to drill it out and thread it like the photo shows. Then, using a length of a M1 .30 Carbine barrel, turn said stub, and thread it to fit said Mauser upper to make a shooter pistol? Barrel stubs are available from Numrich. I doubt that the owner of one of these beaters would care less about hiding the seam.
    Curious to hear your responses.
    remember don bell talking about how when he was bringing guns in from china back when it just opened up he had a line on tens of thousands of c96's he told us that in china there were caves full of guns that had been there's for years and if he took all of them they were $2.50 each but he had blown his wad on other things and he could not find a backer to go in with him so back in the day when all them rusted up junkers cam it that was the deal
  18. #55
    Jul 2018
    Wisconsin
    290
    75
    206
    Some time ago I acquired a Chinese surplus C-96 with a horrible bore. I chose to have it re-rifled for the 9mm.
    Just an option.
