Hello all, I'm looking for some experienced advice on a fabrication question. I'm building a single shot shell holder style 50 BMG (ala ULR 50) and incorporating a Remington 700 trigger take advantage of a couple spare Timney's I have lying around. I'll be using 4140 HTSR steel for the bolt and reciever.
Although it pains me to say this, I've been a lurker on this forum for too long not to throw out a few pre-emptive answers to the inevitable questions that follow a post about designing your own firearm haha.
- Yes, I am fully aware I can easily purchase a fully functional rifle from a store and it will shoot just fine. The point of this project is because I find it immensely enjoyable and satisfying.
- Yes, I have done the math on my initial design (utilizing the excellent article written by Dan Lilja on bolt lug strength and his formulas for calculating shear, flex, and yeild). The SF under a worst case pressure event, case head seperation of a proof load, is around 4.99 (don't have my math in front of me). To chase safety even further I will also throw my final design through a FEA upon completion.
- While I'm not a professional gunsmith / engineer / heat treater, I have been quite successful in all my blue printing, rebarreling, and trigger work so I'm confident in my skills to safely and accurately make my dreams a reality.
- Asking for real world advice is simply augmenting information I've already gathered from other sources. As any tradesman can tell you, real life can often depart from an engineer's well laid plans. No offense to engineers hahaha.
Now down to the real question I'd like to throw out there. How much extra meat should I leave on my work before I send it off to get heat treated (professionally)? I've read varying reports on warping that occurs during the process. Some say that you should leave 0.025 for final fitting, and others have claimed to see negligible warping after HT when using 4140 HTSR. Initial hardness claims to be around 32 RC, but I want to go to 40 on the bolt and 38 for the reciever.
For those of you that have been down this road what have you experienced for warp and how much have you allowed for finishing?
Should I finish my barrel threads to full depth?
Should I bother tapping the other smaller holes (scope rail, trigger hanger etc.)? I'm worried that with the final RC I'll get into hot water trying to use a small diameter tap.
Since my design excludes an ejection port and full length raceways it will be fairly robust and simple. Thanks for your opinions!
