relining larger than 22 barrels
Results 1 to 15 of 15
    Sep 2012
    California, Ventura county
    1,448
    261
    609
    Default relining larger than 22 barrels
    any one here actually done a larger caliber relining job
    not sent it out but done it
    Redmans makes them in 38 55 the cal.
    I want to do but was wondering if you could glue them in
    or if you need to it with solder?
    old gun will be black powder only for me, and not worried about the
    next guy who has it after I'm dead
    yes I can buy a new barrel from greenmoutain
    not a huge difference in price
    Nov 2013
    Eastern Massachusetts, USA
    4,971
    4912
    4886
    Quote Originally Posted by 72bwhite View Post
    Never done it but Brownells says you can Acraglas them in place. HOWEVER, 38-55 is more powerful than what they show as approved cartridges. I would ask Redmans directly.
    REDMANS CENTERFIRE BARREL LINER | Brownells
    EDIT: Track of the Wolf lists barrel liners for 38-55 (item # LINER-38-55-A) sold by the inch. I would give them a call.
    Barrel liners: breech loading rifle bore liners - Track of the Wolf
    Oct 2002
    Poetry Texas USA
    1,803
    343
    235
    Just got my #2 Rolling Block back from Dennis Earhardt. He relined it as a 32-20 as it was originally. It shoots very well.
    Sep 2012
    1,448
    261
    609
    Quote Originally Posted by Butch Lambert View Post
    wouldn't mind having one of those mostly you see them in 32 rimfire
    I will be doing it on a #1 that was in 50 cal.
    for what I want to do with it 38 55 or 32 40 is a good choice
    Remington rolling blocks are interesting I like em
    I don't want a 45 70 or 50 70 not hunting buffalo or trying to knock down steel a 500 yard
    Oct 2002
    Poetry Texas USA
    1,803
    343
    235
    I do have one in 45-70 and am finishing a 22rf. I kinda like them.
    Jul 2011
    Brusly, LA
    765
    21
    302
    I believe the gunsmith John Taylor re lines centerfire bpcr stuff. He’s active on castboolitts forum and is pretty helpful and open about his work.
    Oct 2002
    Poetry Texas USA
    1,803
    343
    235
    Quote Originally Posted by akajun View Post
    He is a good guy, but was to far behind for my project. Dennis was 2 months.
    Dec 2007
    Klamath Falls, OR
    5
    I have lined 3 centerfire rifles in my home shop. 22hornet, 25-20, and 25-35. All were 1/2" dia. liners. Put them all in with Loctite sleeve retaining compound. I like to have around 2-3 thou clearance for the Loctite. None of them have shown any sign of moving. I shoot mostly cast lead, but proofed them with a substantial jacketed load. They shoot good.
  9. Likes Pete Deal liked this post
  10. #9
    Dec 2012
    AUSTRALIA
    2,614
    10
    817
    Anyone with a lathe can do it......Glue is quick and easy,also very permanent......whereas solder can be remelted in an instant if you stuff up the chamber or something.,and the liner moved back a bit......tip...... never cut the liner off untill the job is finished ,for sure.
  11. #10
    Oct 2002
    Poetry Texas USA
    1,803
    343
    235
    So after the liner is installed you have to cut the chamber if I understand it correctly.
  12. #11
    Sep 2012
    1,448
    261
    609
    Quote Originally Posted by john.k View Post
    that was my thinking,
    in the direction I found online chamber was reamed before insertion
    do have to find a long enough liner too those old
    buffalo guns have long barrels
  13. #12
    Aug 2010
    Missoula, Mt
    15
    Most epoxies will also soften under heat if you need to pull the liner but I prefer solder. If you want an invisible job stop the drill just short of the muzzle and gently ream the balance of the bore. You can't see the liner from the muzzle that way. I have done longer barrels and freebored the distance to the muzzle when I couldn't get a long enough liner but it's not as nice.
  14. Likes Davester liked this post
  15. #13
    Jan 2006
    482
    55
    For my money the only to secure the liner is a Loctite retaining compound like 603 or 638. Solder is a terrific PIA and totally unnecessary. Epoxy is too thick and sticky. Drill the liner hole 2-3 thou. over the liner OD and insert it vertically keeping a puddle of Loctite around the liner at the entry point. The liquid will fill all the voids and once cured is totally solid. Chamber after it cures since the liner is too thin to support the chamber reamer and make it cut properly. The liner can be removed, but you will have to heat the barrel full length to over 400 deg. On 22 barrels, the barrel material is usually soft and when you crown it with the liner in place, the joint will disappear under a tiny burr and the liner will be invisible at the muzzle. This works best when the barrel bore is a snug fit on the liner. I made my extended barrel drill out of a 8mm twist drill ground with the pilot integral. It does a nice job for Redman's 5/16" dia. liners.
    RWO
  16. Likes Butch Lambert liked this post
  17. #14
    Apr 2008
    West Coast
    289
    58
    53
    I've done a few. Here is a 1885 Win High Wall being relined to original 38-55 caliber with TJ's liner. Customer wanted to keep the original barrel markings. Someone had installed a new chamber in the past, along with a very sloppy firing pin bush job. Loctite 638 is the go-to stickum for liners. More pictures here Ken Breda - Fun project at hand. Relining an 1885... | Facebook
    win-1885-barrel-liner-install-8-.jpgwin-1885-barrel-liner-install-29-.jpgwin-1885-barrel-liner-install-25-.jpgwin-1885-barrel-liner-install-23-.jpgwin-1885-barrel-liner-install-2-.jpg
  18. #15
    Sep 2012
    1,448
    261
    609
    unfortunately when I took the barrel off and measured it,
    bubba really did a number on it drilled ok for a liner and then had to
    bore it out even larger for about 3 inches on the chamber end.
    so no way to use a standard TJ's liner.
    so it's getting a new barrel already have it just need to feel energetic enough to just do it.
    I'm lazy so just got 2 of the square thread cutting tools from Brownells.
    do a practice stub and the rent a reamer not going to buy one for probably only 1 chamber.
    original doesn't have any Remington markings other the serial number and cal
    so not that big a deal.
    If done right in 20 years or so when the next guy gets it no one will even know it isn't
    original. not that I care that much any way.
    did get some good information for when the next guy does a search maybe.
