Removing weight from a A2 Hbar barrel caalculating weight removed?
mac1911
Feb 23, 2019
Long time lurker, first post
I have a frankenbuild project. Its being done with parts on hand. My rifle that was legal for the last few years is no longer legal this year in the match I shoot.
I bought what I was led to believe was a A2 government profile barrel. upon inspection (removed the A2 hand guards for a free float install) it was clear my "a2" is really a "Hbar style" I already cut off the muzzle brake(muzzle devices need to be pinned and welded here) and about 1" of barrel to make the install of the hand guards easier. Plus i have no intention of installing any muzzle devices.
Any how I still need to shed about 1.0 lbs.
The barrel has a 10" area between the barrel "lug" and the gas block measuring .950" the original A2 is aprox .675 tapered from the chamber to the gas block thats .750"
I was wondering
1. the best method of removing metal A. Fluting or even just flat side cuts? B. remove metal around the complete circumference?
2. How much weight would be shed if I removed metal from the 10" thats .950" down to .750" ?
Since this is not a "high accuracy or value rifle" Looks dont matter. End result it needs to hold 3 min or better....it does already.
thank you
Eat a salad ;)
Seriously though, you need to shed just under 4 cubic inches. On a 26” Rem varminter I can shed 6oz with standard 6 flutes and 8oz with spiral flutes. Hope this helps a bit
Eat a salad ;)
thanks, very new to "machine" work. Im no stranger to tools or taking time to learn.
as for the salads..... I had to shed pounds myself as my shooting jacket is defective and it keeps shrinking!
This is why they gave us word problems in math class.
The barrel is probably 4140, or an alloy close enough that it won’t matter, Look up the density of 4140, and figure out how much volume you need to remove to lose 1 pound. Figure out how much of the barrel diameter needs to be removed to take out the proper volume of steel. Put the barrel on a lathe, and remove it. Or put it in a mill and flute it.
Lots of math. The bonus is that when you are done, and someone ask if you ever use geometry and algebra in real life, you can say yes.
A cylinder .750" ID x .950" OD x 10" long made from 4130 would weigh approximately .757 pounds. Combine that with some barrel fluting forward of the gas block ought to get you that 1 pound total weight loss.
dhg2
Im not so sure i did the math right but I basically said to myself
.950 x 10" 7 in3 ( if thats even how you right it)
Vs .750 is 4.4 cuin3 or about 12oz plus what ever I can shave off the 4" in front of the gas block. Was thinking of just milling 4 flats and retain some of the barrel radius for looks. Plus I can still cut a few inches off the muzzle end for about 2 oz per inch.
made weight
I finished up a little while ago. Made weight and It shoots as well now as before so that's good....
lost about 11oz trimming down the .750" thick section under the hand guards
Also cut off the welded on muzzle brake I did not like plus another few inches off barrel now its 17.00033400556677" long.
11' crown
did a little "decorative" work on the barrel
Installed the lightest free float I had on hand
Thanks to all that helped and provided links
