Rifle Re-Chambering Question - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41
    Jun 2012
    Michigan
    10,196
    3459
    3645
    OT:
    For you guy actually doing gun work..How close is the chamber end and the breach end to the center of the OD.
    what are you finding on barrels..yes if you are even checking that)?). Not a whole lot you can do about it.
    Is this different by manufacturer, and are high end guns better.
  2. #42
    Oct 2002
    Poetry Texas USA
    1,791
    335
    233
    Quote Originally Posted by 75sv1 View Post
    You can, but you'd have to know the form fault of the surface being measured. IE, how round is the round part. If we look at the flip side of this, a range rod is used, on the bore. Correct me if that is not correct. So, it is to 3 circumcised points, or at least five, since it would be a cylinder. I tried this example on a previous chambering thread. HK uses a fluted chamber. So, what is the run out? Is it concentric? Or even a spline on a shaft. The OP would need to index, ie mark the high spot. Rotate through. See if the high spot is in one direction only. I think some chambering processes do not use a piloted reamer.
    Sir, the custom barrels that I use are gun drilled, reamed. and finished with a specialized Sunnen hone before rifling. Form fault? I was circumcised as an infant. As mentioned, you could chamber by hand, but I would only finish reaming by hand. A match grade barrel from the better barrel builders will be within .0001 in tolerance end to end of the bore. I'm saying bore size from end to end. Bores can meander through the barrel, but not in an arc as some call it.
    A range rod? What will it do for you?
  3. #43
    Oct 2002
    Poetry Texas USA
    1,791
    335
    233
    Quote Originally Posted by michiganbuck View Post
    OT:
    It would only matter if you are chambering in the steady. If chambering through the headstock you indicate the bore and not the OD. Only time I check the OD is at the muzzle after threading and installing a muzzle device. Indicate the bore to turn and thread, then with the muzzle device installed, indicate the OD and turn the muzzle device to match the OD of the barrel.
  4. #44
    Jun 2012
    Michigan
    10,196
    3459
    3645
    Quote Originally Posted by Butch Lambert View Post
    Agree to that but was just wondering how centered to bore is expected to be to the OD.
    Seems better centered might effect better accuracy with a barrel getting warm/hot.
    What factors make the higher priced barrels better.
    Seems like Kenny Jarrett claims .0003 or some figure on size...
    Seems I read once .010 to center, and now a days that does not seem that close. I forget now what manufacturer or who said that.
  5. #45
    Oct 2002
    Poetry Texas USA
    1,791
    335
    233
    Harold Broughton sold Kenny his machines years ago when he (Harold) bought new stuff. I don't think Kenny's or anybody else's barrels are .0003 from bore center to OD. Most are contoured between centers on a CNC lathe.
  6. Likes gappmast liked this post
  7. #46
    Aug 2005
    Tucson AZ
    6,372
    9618
    3002
    "Form fault"? WTF are you talking about? The only results of a search for "form fault" is when a Datamax printer does not index the print, specifically a label.
    It does not matter of either feature is perfectly round. If you sweep it then you know that and you will know for instance if an oval is centered on a circle. One sweep will not tell you that.
    Don't try to blow smoke up our asses.
  8. Likes Butch Lambert liked this post
  9. #47
    Dec 2005
    Waukesha, WI
    1,735
    410
    554
    This is one of the things that happens when you use circumcised points instead of circumscribed points.
  10. Likes tdmidget, Butch Lambert liked this post
  11. #48
    Jul 2009
    hope,in
    652
    32
    39
    Range Rods - Pacific Tool and Gauge
    I thought it was the term for the part you put in the barrel end so you can true it up. ???? Also, I believe it was not your barrel that the issue was with.
    TDMidget:
    I did a search for Form Fault. Gave me plenty of results. I narrowed it to Metrology. It gave Form Error.
    Circumscribed and inscribed are basic geometry terms. I should have used inscribed.
    Do we know this chamber is 'oval'?
    Well, there are other gunsmithing forums. I won't waste my time here.
  12. #49
    Aug 2005
    Tucson AZ
    6,372
    9618
    3002
    TDMidget:
    Good luck on finding one that likes people who try to impress with words that they do not understand. Circumcise comes to mind. If you had looked in the metrology forum instead of trying to find a term to impress us you might have found that an oval can be concentric to a square. It doesn't have to be round.
  13. Likes Butch Lambert, gappmast liked this post
  14. #50
    Oct 2002
    Poetry Texas USA
    1,791
    335
    233
    TDMidget:
    I know some people, mostly newbies, use range rods. Before commenting on this poll a few of the top BR gunsmiths and check their methods. Oval chamber? How do you ream an oval chamber.
    If you go to some of the gunsmith's forums and pick through the chaff, it might help you to learn how a gunsmith thinks and practices. You have a lot to learn young feller and I see your type on some of the gunsmiths forums. You need to visit a couple of the better barrel makers shops and they will give you a lesson on barrel making. You are leaving this topic because you don't like the answers that are given.
  15. Likes gappmast liked this post
