Zip
- May 25, 2007
- Champlain, NY
Just drilled and tapped a S&W Model 10 trigger to fit a 6-32 set screw as an external trigger stop. Broke a tap that luckily came out easily. Want to install another stop in a second S&W trigger, prefer the external over the internal rebound slide method.
Used a 7/64 drill bit and had a heck of a time cutting into the trigger with the tap. Any suggestions to make the process a little easier (ie larger drill?).
thanks
thanks
