T/C Dimension/Venture firing pin disassembly
Likes Likes:  0
Results 1 to 2 of 2
    Mar 2005
    Maine
    1,346
    9
    567
    Default T/C Dimension/Venture firing pin disassembly
    Does anyone know how to get the firing pin apart to change the spring?
    There's a flat on the pin at the forward end of the spring that I've turned as hard as I dare with no movement.
    I figured I'd ask before I broke something.
    Mar 2005
    Maine
    1,346
    9
    567
    Just to finish off this post for any future searchers.
    The firing pin threads are lock tited in the cocking piece.
    Gentle heat, maybe 200 degrees, and a 10mm wrench on the flats of the firing pin and it unscrews.
