I have a nicely sporterized US 1917 rifle in need of a modern scope mount set up. The rifle was converted to 300 H&H, high polish blue and a handsome sporter stock added. The issue I have is when the rear sight ears were ground off, there was no effort to match the top surface of the rear receiver ring with the front receiver ring. It is about .040" taller. When it was originally reworked, an Echo side mount was installed so this dimension did not matter. I tried to find an Echo mount that will accept a 1" scope but they do not provide enough height for objective bell clearance.
My current plan is fit a plug in the "well" that exists at the rear of the receiver (an artifact from the original military) sight, TIG weld it in place and then mill the rear receiver ring flat to match the top of the front ring. I have two piece Weaver mounts (#11) and will mill one flat on the bottom to use at the rear. theoretically, this will give two Weaver bases that are on the same plane. Anybody have any thoughts on this or a better idea?
