I just had an old 20 gauge bolt action shotgun modified by a local smith. I verified he had all the appropriate tools and experience to ream the fixed full choke to an improved cylinder for better rifled slug performance.
When I went to get the gun he started complaining about how the choke was really deep and he had issues. I got the gun home and looked down the muzzle end w a light. I'm concerned. He went at the job from the muzzle end for one thing. He reamed 3 and 1/8 inches out and stopped. So now there is what I would call a cut-ridge and a really rough 3 and 1/8 inches at the end of the muzzle that is more open than the deeper part of the barrel.
I called the smith today and expressed my concern, he offered to refund me my money. I think he knows he buggered the gun up. I asked if he had ever seen a gun with a more open muzzle than the tightest point of restriction and he said yes, all the time. He said he had to go that deep to get the fixed choke restriction out. I asked if what I'm seeing at the muzzle end is imp. cylinder diameter or more open and he said it is closer to cylinder bore diameter but that the restriction I'm seeing deeper into the muzzle is less than full choke.
His advice was to go shoot the gun and see if I'm happy with it. I am not concerned about safety, I'm just unsure that what I've ended up with is going to be accurate at all since the rifled slug will swage down at the tightest barrel point and then have quite a bit of room the last 3 and 1/8 inches of travel out the barrel.
Please advise on if this is acceptable or if I should go have the barrel cut down behind what he did and just live with whatever bore diameter of have at that length? The barrel is currently 26 inches, so I know I don't need that much barrel for a slug gun.
Thanks!
Thanks!
