Smallest lathe for chambering
Results 1 to 5 of 5
    Mar 2019
    Arkansas
    Default Smallest lathe for chambering
    Hello. What is the smallest lathe I can get away with for barrel chambering between centers? Not just from a length standpoint but will smaller lathes have the power
    Aug 2015
    Illinois
    1,268
    902
    531
    I have done it on a 9" South Bend. If the barrel will not go through the spindle then the limiting factor is bed length.
    Mar 2006
    New Jersey
    1,068
    11
    279
    A 9"South Bend if the bed is 4' and have a steady rest. A heavy 10 with a shorter bed will work if you work thru the headstock.
    Mar 2019
    ALAND ISLANDS
    14
    5
    I have a 40” bed and I’ve chambered a 25” finished length barrel between centers. Never paid too much attention but I bet it would be hard pressed to go much past 28-30” given the length of my machine’s tail stock.
    Been my experience that it doesn’t take a lot of power to do barrel work. Cuts are fine for the most part.
    Sep 2010
    moscow,ohio
    5,693
    551
    1800
    maybe instead of what's the smallest you might ask what is the best I can get into space,power and weight constraints within my budget.
  6. Likes MIBill liked this post
