Split barrel
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Split barrel
    Oct 2016
    Ohio
    17
    Default Split barrel
    Hello, i’m making a single shot pistol in cal. 22 long rifle, and i got two very short barrels for .22, can i use these barrels as one, using a steel pipe that the barrels fit inside of, and some epoxy or JB weld to keep everything in place?
  2. Likes muckalee liked this post
  3. #2
    Nov 2017
    Kansas
    335
    76
    154
    Is it going to be a gift for your mother in law?
  4. Likes MetalCarnage, Dupa3872 liked this post
  5. #3
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,244
    1118
    673
    You can, but I do not want to be anywhere near you when test fired. Just buy a barrel, you cannot buy hands or a new life.
  6. #4
    Jun 2012
    Michigan
    10,196
    3459
    3646
    Quote Originally Posted by Monday View Post
    Just this one work would not post because one word is to shot a post
    No.
  7. #5
    Nov 2017
    Kansas
    335
    76
    154
    Better yet, is it for my mother in law?
  8. #6
    Oct 2016
    Ohio
    17
    A revolver got a ”splitted barrel”, the cylinder and barrel isn’t solid.
  9. #7
    Oct 2016
    Ohio
    17
    This is what i’m talking about Imgur: The magic of the Internet
    If the problem is that the gas will escape in the middle of the barrel, and the epoxy would’nt be strong enough to hold the barrel together, even though it’s supported along, would the solution be to make went holes and leave a small gap between the barrels?
    It would basically be like a revolver ”barrel” then?
  10. #8
    Oct 2016
    Ohio
    17
    If i thread the barrels and pipe instead of useing epoxy, would that be enough to hold it in place?
    Like a suppressor
  11. #9
    Nov 2014
    Ohio
    43
    10
    OMG, I was going to post something here, but deleted all I had to say, and I advise everyone here to stop encouraging you to continue posting on this forum. This added with your other posts, I can see any advise ending up in court someday. Please stop working on anything other than squirt guns.
  12. #10
    Oct 2016
    Ohio
    17
    What’s the matter? I’m just collecting information and thoughts. It’s not illegal, giving advise isn’t illegal neither. Why would anything end up in court?
  13. #11
    Jun 2012
    Michigan
    10,196
    3459
    3646
    an old 60s radio antena..opps forget I started that...Im not me...
  14. #12
    Dec 2012
    ny usa
    513
    272
    Only one way to be the first at anything.....
  15. #13
    May 2017
    Minnesota
    1,087
    1346
    735
    In theory, if everything is strong enough, it could work and be legal. The interrupted and probably not aligned rifling would destroy any accuracy. There could also be a danger of a bullet becoming lodged in the barrel at the transition, causing the next shot to explode the gun. Don't do it.
  16. #14
    Oct 2010
    Dewees Texas
    2,401
    27
    657
    I am not sure that you know that liners can be purchased and glued in an old shot out barrel that has been drilled to the appropriate size. Technically what you ask could be done by someone that took their time and did it right, but using a piece of pipe that does not even have a round hole, pieces of barrel that will not have the bore in the middle, it would be easy to get a 50% mismatch in alignment of the 2 barrels. 25% or more mismatch and it will probably come UNGLUED the first shot.
    Not worth the effort to even try on something that has little chance of being accurate. There are too many old 22 barrels of any length you want that the actions are worn out and can be had for next to nothing or probably nothing to spend time with something that will most like give poor results even with a lot of effort to make it reasonably safe. I needed a longer barrel on a cheap revolver to control varmints, I walked into a gunsmith's shop and he gave me 12 inches of brand new 22 heavy target barrel. If can not find the appropriate length of 22 barrel for little or nothing it is because you have not tried.
  17. #15
    Aug 2003
    New York
    136
    10
    37
    Bad idea for all the reasons mentioned. Don't do it.
  18. #16
    Virginia
    27,746
    7561
    8632
    Quote Originally Posted by michiganbuck View Post
    No.
    Been done.
    Just not with JB weld and pipe.
    See "HARP" gun.
    It should scale down OK. Stupidity would scale UP, inversely, of course
    OTOH, stupidity seems to be ever in surplus...
    See also a movie "The American". George Clooney.
    The story is fictional. The sort of barrel depicted as DIY?
    Those have actually existed for "specialized needs". Expensive to do. Very.
    If this thread is not a trolling project?
    It is surely missing an excellent opportunity for it.
  19. #17
    Jun 2009
    Near:Louisville, KY
    1,727
    187
    386
    'Nuther attempt for a Darwin Award.....
  20. #18
    Dec 2012
    AUSTRALIA
    2,300
    10
    702
    The WW2 3.9" AA guns had three loose sections of liner in an outer tube,but possibly stronger than a bit of gal pipe...Still ,its only a 22......1 grain of powder cant do much......always assuming you dont stand in front as it fires.
  21. #19
    Nov 2004
    RC, CA
    1,974
    211
    376
    I fiddled a bit with a rifled extension tube some years back. Had an aluminum coupler, ported, and the 2 pieces about 3/4 to 1" apart. Cut a leadin with a Bentz reamer. Everything was indicated in for alignment when machined.
    Main barrel a 1-18 twist, extension a 1-16, both Lilja. I tried to eyeball the rifling into alignment, but there's no way it was perfect. And with the different twist it was probably going to shear a bit anyway.
    Didn't shave lead, didn't shoot any better. Don't remember it shooting significantly worse either.
  22. #20
    Aug 2011
    Oregon
    2,557
    584
    779
    As with the OP I have to wonder why, but in your case I suspect you had a better reason. Had you thought of casting a slug to use to align the riflings?
    I advise people to get good advice, or else my advice is to not advise. a play on words to show spelling.
