Spray On Finish Curing Temperature
Results 1 to 9 of 9
    May 2006
    Longview,TX
    1,023
    6
    15
    Default Spray On Finish Curing Temperature
    Anybody familiar with the curing temperature for the spray on finishes?
    Jan 2015
    Missouri
    961
    210
    591
    225 degrees for 2 hours on metal parts
    Cerakote
    Dec 2017
    Idaho
    364
    104
    83
    300 for 1 hour on metal parts. Google cerakote application
    Jan 2015
    Missouri
    961
    210
    591
    Quote Originally Posted by Mram10 View Post
    Sometimes it bubbles at the higher temps. So I do the lower temp for 2 hours. I have not had any of the bubbling at the lower temp
    Dec 2017
    Idaho
    364
    104
    83
    Never had any bubbles and the manufacturer recommends both ways.
    Feb 2019
    Massachusetts
    20
    7
    Quote Originally Posted by deltaenterprizes View Post
    What finish?
    Often bubbles in oven cured finishes is contaminated surface.
    Dec 2017
    Idaho
    364
    104
    83
    Prep is definitely everything. Baked on cerakote has given me much better results than polane, Durakote and other air drying types. Basics for me:
    Sand barreled action with 400grit ao on palm sander
    Dip in steel tube of acetone to verify all parts are hit
    Soak in acetone tube overnight
    Cook barreled action in oven for an hour at 300
    Check and wipe down lightly
    Shoot with cerakote and cook at 300 for an hour
    Let cool and put her back together
    Very easy. Blasting not needed even though it’s nice to have
    Jan 2015
    Missouri
    961
    210
    591
    here are a couple cerakote AR 10 s
  9. Likes MetalCarnage liked this post
  10. #9
    Sep 2013
    Michigan
    254
    89
    151
    Blast as appropriate for the material. Wash with clean mineral spirits and subsequently in acetone. Fixture parts, if heat tolerant, warm with propane torch until “wetness” (when you do it, you’ll know what I’m talking about) goes away. Go mix your Cerakote, spray parts, bake at 250 for 2-3 hrs.
    Never ever had a bubble.
