Stock duplicator
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jun 2018
    Kentucky
    Default Stock duplicator
    Has anyone made a stock duplicator? I can’t afford to buy one and would like to make my own. Are there any suggestions or tips?
    Sep 2003
    Pacific NW
    751
    7
    86
    Les Brooks over at accuratereloading has plans for $10 or so. He was/is a professional stockmaker and certainly used his alot. It is a knock down model for storage.
    Gunsmithing - Forum
    Oct 2005
    15,612
    Here's one for you:
    duplicator
    Only $14k, and "the best machine"......
    Mar 2011
    Huron
    1,355
    1909
    846
    The tool and die maker I trained under had a stock duplicator rigged up; he made his own blackpowder rifles, from forging and rifling the barrels to heat treating his own locks and springs. It was basically a geared down hydraulic follower lathe, and a router fixtured onto the tool post, if I recall correctly. The master was chain driven off the blank with a bicycle chain and sprockets, to keep them rotating at the same speed. I never saw it running so I can't give you any more than that, but I imagine if you had a lathe with a taper attachment, you could get a similar effect by swapping the taper bar for pair of centers.
    May 2017
    Minnesota
    1,087
    1346
    735
    Quote Originally Posted by Vee1948 View Post
    My guy reordered some bar stock instead of the bandsaw blades I wanted him to, now I have duplicate stock.
  6. Likes digger doug, Oldwrench liked this post
    Jan 2008
    Mountains of Washington State, USA
    434
    135
    The Les Brooks duplicator is a good one, he has a video also. Get in touch with him, he is a master gun builder and stock maker.
    Brooks duplicator below:
    I have a NorthStar, an unusual machine:
    Sep 2004
    NH
    1,137
    90
    I have a friend who has one, a North Star 2 spindle that he would like to sell. I'm not sure how much though but could find out if your interested in a factory made one.
  9. #8
    Oct 2005
    15,612
    How do you make the first one to duplicate from ?
  10. #9
    Nov 2017
    Kansas
    333
    75
    153
    I have made a few with hammers, chisels, and rasps. Fore stocks are tedious. They never seem to look right until they are checkered.
  11. #10
    Oct 2005
    15,612
    Quote Originally Posted by Aejgx6 View Post
    Why not draw it on CAD once...
  12. Likes Aejgx6 liked this post
  13. #11
    Nov 2017
    Kansas
    333
    75
    153
    I used to enjoy some of the more primitive arts. Don’t worry, I’m well past that now. It was a monumental waste of time when you consider the cost of a nice replacement stock, and I have yet to make any money with a bang bang stick.
  14. #12
    Jan 2008
    434
    135
    By hand as the previous poster said.
    Or modify an old stock. Add wood, use bondo, to get the stock to your desired dimensions. I have maybe 50 patterns, the ones in the photo below are the most used.
    Determine your dimensions the make the pattern stock to fit: Proper length of pull, drop at comb and heel. cast off, toe out, butt plate size, etc. A properly fitted stock makes a lot of difference in sight alignment, recoil management and handling. Iron sighted rifles, especially big bores, need a lot of cast off and drop to be useful.
    I make a functional pattern, properly bedded to the barreled action, before making the final stock. The pattern is used in test firing the rifle to ensure proper fitting. Then the final stock is duplicated.
    If you want I will put up some photos of making patterns.
  15. Likes mhajicek liked this post
  16. #13
    Jan 2008
    434
    135
    Quote Originally Posted by Gazz View Post
    The NorthStar is a good, heavy, accurate machine. Needs some modification and custom tooling made for the gunstock work. I will put up a link if anyone wants to see how they work.
  17. #14
    Jan 2008
    434
    135
    Nice drawings are a good thing, but you still have to go through the exercise of making a prototype and changing things until the stock fits. There is more art than science to making a good fitting stock. The prototype, after modifications, turns into your pattern.
    The real work in duplicating stocks is in making the patterns. Once the pattern is successful, then start cutting into expensive wood.
  18. #15
    Mar 2007
    Belgrade, MT USA
    61
    How can i contact Les Brooks to purchase his plans? i have contacted the accuratereloading.com web site and no one knows what i am talking about.
  19. #16
    Feb 2003
    Arkansas
    477
    7
    27
    Quote Originally Posted by Petergun View Post
    Stockmaker show and tell - Topic link is to a thread started by Les. Go there and send a pm to Les, letting him know whar you want.
  20. #17
    May 2017
    Minnesota
    1,087
    1346
    735
    Quote Originally Posted by SilveradoHauler View Post
    Looks a lot like a guitar makers shop.
  21. #18
    Jun 2018
    Idaho
    13
    really don't need any plans
    just set up to make 8 or 10 inch centers and start making parts
    no big secrets
  22. #19
    Mar 2007
    Belgrade, MT USA
    61
    I am having trouble getting on the accuratereloading web site. it will not allow me to send him an email. I don't have his phone # either
    Hope some one can be of help.
  23. #20
    Feb 2003
    Arkansas
    477
    7
    27
    2 PM's sent
