A friend was shooting his new PTR (HK 91(?) clone) which is chambered in .308 or 7.62x51 and one of HIS friends loaded a magazine with one round of 7.62x54r mixed with the correct ammo. The live round is quite firmly wedged in the chamber and while I have soaked it with bore cleanter with ammonia in an attempt to break down the copper jacket some and added oil it has not budged with a steel rod down the bore and 2 pound hammer to drive it out. I have added the bore cleaner to both the bore and to exposed portion of the base of the case with no luck. If I have to, I will press out the cross pin that holds the barrel in the trunnion and then press the barrel out but that is worst case. Anybody have any ideas on how I might get this out without removing the barrel?
