Results 1 to 2 of 2
10-23-2019, 01:30 PM #1
T/C Dimension/Venture firing pin disassembly
Does anyone know how to get the firing pin apart to change the spring?
There's a flat on the pin at the forward end of the spring that I've turned as hard as I dare with no movement.
I figured I'd ask before I broke something.
10-28-2019, 05:29 PM #2
Just to finish off this post for any future searchers.
The firing pin threads are lock tited in the cocking piece.
Gentle heat, maybe 200 degrees, and a 10mm wrench on the flats of the firing pin and it unscrews.
