smootz
Stainless
- Dec 5, 2005
- Southern Ohio
I typically post in the General section as I am not a gunsmith.
I just bought a Leupold base and rings for my 686. It is an older model that was not tapped from the factory. After viewing the sorry equipment that my dealer intended to use on my gun I decided that I should maybe try this myself.
DSCF0630 by jsmootz, on Flickr
The gun is SS and will require 3 holes, two are centered in the back strap and a third just ahead of the hole that mounted the open sight. The front hole will be "blind".
The provided screws mic .136 and are approx 46 - 48 pitch best I can tell. I'll need a bigger magnifying glass to determine for sure.
I have a couple of regular drill presses and a Bridgeport Vertical Mill. Can anyone give me advise on procedure and fixturing so I don't ruin this gun?
Thanks, SCOTTIE
Thanks, SCOTTIE
