Grizzlypeg
- Aug 20, 2012
- Canada
When truing internal threads with a single point cutter, do you use only the cross feed to advance the cut deeper?
I do this when cutting new threads, but when truing receiver threads I would think it would be better to use the crosslide to keep the cutting tool in direct alignment with the original threads.The most common--but certainly not the only--way to cut threads is to set the compound to 29-1/2 degrees and cut the majority of the thread by feeding the compound in deeper. The tool cuts easier because it's only cutting on one side. For the finish passes (.003" - .005") feed in with the cross-slide. This forces the tool to cut on both sides and normally leaves you with a nice clean finish...
How heavy of a boring bar do you use for holding the internal threading tool? Is 3/8 too light?
Senseless, really. I must have SOMETHING better to do with my time?
Notice
