Weaver scope base angles?
Results 1 to 12 of 12
    May 2007
    Champlain, NY
    55
    37
    Default Weaver scope base angles?
    What angle is used to make a Weaver style base? If I remember correctly they are not true 45 degree angles.
    Jan 2006
    482
    55
    make it like this and you will be close enough: http://www.biggerhammer.net/picatinny/1913_specs.pdf
    RWO
  3. Likes Zip liked this post
    Jun 2012
    Michigan
    10,418
    3549
    3715
    This not related to your question but an interesting site.
    Scope Calculator
    And:
    Sites-VistaFederal-Site
  5. Likes Zip liked this post
  6. #4
    May 2007
    Champlain, NY
    55
    37
    Thanks guys...great stuff!
  7. #5
    Oct 2010
    Dewees Texas
    2,486
    28
    703
    I was worried that I had built all my bases wrong. I have made 3 of them all with 45s. The attached photo shows a double 45 tool that I used on the last one, this was the easiest so far. Tool is spinning so it looks solid.
  8. Likes Lharmon, Zip liked this post
  9. #6
    May 2007
    Champlain, NY
    55
    37
    Quote Originally Posted by FredC View Post
    That is awesome...where could I pick one of those up?
    Thanks!
  10. #7
    Oct 2010
    Dewees Texas
    2,486
    28
    703
    MSC catalog item. Mine is still here somewhere but I have not seen it in 6 months. A couple more photos, generating the radius and finished. The radius was generated using Guy Lautards method from his book Ball and Radius Generation. Used his ideas and made a CAD drawing to plot the curve.
  11. Likes Zip liked this post
  12. #8
    Nov 2012
    Michigan
    607
    196
    178
    Quote Originally Posted by Zip View Post
    Thanks!
    Harvey Tool - Double Angle Cutter
    have a couple of these I use for various purposes including a couple for thread milling. Click on the included angle you want at the middle of the page and it will take you to the full selection.
    OR:
    Harvey Tool - Picatinny Form Cutters - Picatinny Attachment Cutters
  13. Likes Zip liked this post
  14. #9
    Nov 2012
    Michigan
    607
    196
    178
    After a bit of looking at what they have available now I should have just posted this link:
  15. Likes Zip liked this post
  16. #10
    May 2007
    Champlain, NY
    55
    37
    Quote Originally Posted by MIBill View Post
    I was just about to ask about the double 45 V rail frame cutter and you have it ! Thanks
  17. #11
    Oct 2010
    Dewees Texas
    2,486
    28
    703
    I looked at the Harvey line and did not like all the clearance the cutter would make under the rail. One could shorten the cutter or modify it to cut an 45 underneath.
    Here is the cutter I had, could not find it in the MSC catalog today:
    3/4" X 90deg Double Angle Cutter
    Remember how much you will be holding in the vice. Now you have lots of good choices. Harvey makes good tools, the cutter I used was purchased many moons ago but is still available and made in the USA.
  18. #12
    Nov 2012
    Michigan
    607
    196
    178
    I used to use MSC years ago but their prices got stupid (I DO NOT know if that is still the case) so I dropped my account there and have not been back. The price for the cutter you linked is VERY reasonable. Definitely worth giving that one a look.
    Some of the Harvey tools are a bit spendy but they are good and they carry a few things that are just damn hard to find... I bought a 1/16" undercutting end mill from them about 15 years ago and still use it. I don't use it a lot but it probably has more hours on it than any other tool I own. It just keeps cutting. And I have a local distributor.
    As far as the form cutter goes... I do not own one but if one were cutting a lot of rails it may be worth the money. It would be easy enough to shorten up if you gound the clearance to be an issue.
