Your Opinions, Please.....
Likes Likes:  0
Results 1 to 5 of 5
    Oct 2003
    Cheyenne, WY
    8
    I will be purchasing a mill and a lathe in the coming months. A well known riflesmith recommended a Clausing-Colchester 15x50 for its size, weight and meehanite construction.
    What say you about this machine? Also, what mill is "as good as it gets"?
    Thanks in advance,
    Ben H
    Aug 2003
    Aloha, Oregon, USA
    If you are going to do a lot of barrel work this would be a good choice. If not I think it is a little big. I have a Clausing 13 X 36 and I find it be just about the right size. On making some small screws it tends to be a little big also but for general gunsmithing and barrel work it is just fine.
    Mill - Bridgeport (or copy) standard knee mill. 12" X 42", power feed and DRO if you can aford it is a big help.
    Good luck.
    Roger
    Oct 2002
    Poetry Texas USA
    1,755
    314
    213
    The 15x50 is a good lathe, but will not allow you to chamber in the headstock. I have a 14x48 Clausing and it took alot of work to be able to chamber in the headstock. I would second the recommendation on a Bridgeport or clone. Thebarrelman
    Oct 2003
    Cheyenne, WY
    8
    Thanks to both of you for your replies. Why can't this lathe be used for chambering through the headstock?
    Thanks again,
    Ben H
    Oct 2001
    Montrose Iowa
    1,180
    I have seen dozens of 15X50 CC but must admit I never measured the head stock length. I have a CC 15X48 and to do a barrel in the head stock the barrel would need to be 32" long. Measure the head stock through hole, add the length of your chuck, and about 2 to 3" for the spider, then add what you need of the barrel to stick out and you will see why.
