1991 vf 1 gearbox rebuild - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Idaho
    151
    82
    51
    Wow.. haven't seen my gearbox rebuild post in 5 years... yup.. she's still runnin
  2. Likes BGL liked this post
  3. #22
    Feb 2014
    Oregon
    20
    Quote Originally Posted by eksinger View Post
    Here I am pulling off the main bearing. Notice the seal behind it. It's an aluminum disk with an o-ring on the outside and the seal gets pressed in on the inside..
    took a week to get the bearings and seals in.. I set them side by side to make sure I knew which was which.. I had marked the old ones with a sharpie and where they went.
    The main bearing has to be installed in housing followed by that funky seal first before installing the gear shaft.. I used lots of petroleum jelly and still sheared off a bit of o-ring.. it's tight enough i'm not seeing a problem. I had to have the guy's at priest electric press on the gear shaft then install the pulley. They have an induction heater so it was a piece of cake for them to do.. Thanks guy's..Attachment 69956Attachment 69957Attachment 69958Attachment 69962Attachment 69963
    Can you tell me if you replaced the Gears? and if so where did you get them from?
  4. #23
    Idaho
    151
    82
    51
    nope.. just the bearings.
