Haas 1998 HS-1RP Troubleshooting(repost) - Page 6
Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 173
  1. #101
    Jun 2019
    Maryland
    432
    72
    Agreed, encoder and rs232 would not burn anything up. what would burn a motor up driver up is if someone used a macro forced output and didn't cancel it. that would cause the motor to want to drive while tool changer was locked by arm with the tool in it. I think what you have proposed is safe and should be a good start !
  2. #102
    Dec 2018
    Arizona
    115
    7
    That' interesting. The air hoses that go to the tool changer were cracked, if the tool changer was commanded to change tools, it would move the y axis up into the carousel and then if the carousel didn't lift the away it would essentially be locked up. if there is no sensor for the carousel lift, that would have caused that problem.
    Sent from my Phone 2 using Tapatalk
  3. #103
    Dec 2018
    Arizona
    115
    7
    Ok so it came with an extra chip, Im assuming this has to do with the motor gear reduction ratio. one says 40:1 the other says 20:1. Ill look at the original chip.
  4. #104
    Dec 2018
    Arizona
    115
    7
    Hopefully its not how many tools the tool carousel holds.
  5. #105
    Jun 2019
    Maryland
    432
    72
    Best bet is call Haas on that 1 to e certain. most of the time they include a sheet explaining the differences with the board. I haven't forgotten you. it's just been Crazy on my end. way to many hrs of work in a 24hr day.
  6. #106
    Dec 2018
    Arizona
    115
    7
    The haas parts guy says it has to do with the gear reduction on the atc. So ill have to have a gander at it and see if its 40:1 or 20:1 or neither.
  7. #107
    Dec 2018
    Arizona
    115
    7
    It says 20:1 right on the gear box, but there is a timing belt that is not 1:1 right after it.
  8. #108
    Dec 2018
    Arizona
    115
    7
    well here goes nothing...
  9. #109
    Dec 2018
    Arizona
    115
    7
    also the reduction at the pulleys is probably more like 4:1
  10. #110
    Dec 2018
    Arizona
    115
    7
    Well no smoke this time, but its still says disconnected. Ill have to go through the settings of the machine to make sure every thing is set correctly.
  11. #111
    Jun 2019
    Maryland
    432
    72
    it should be the 20 to 1 as it should match the gearbox. there should be a parameter that is marked t.c. disabled.if its 1 change it to a 0. does the machine have a vector drive? if it doesn't and you cant find t.c. disabled. it may be called C axis disabled.
  12. #112
    Dec 2018
    Arizona
    115
    7
    yeah it has the vector drive, I did change that parameter to 0 and it still errored out.
  13. #113
    Dec 2018
    Arizona
    115
    7
    What about the baud rate settings and the aux axis sync?
  14. #114
    Jun 2019
    Maryland
    432
    72
    no that is controlled rs232. that's for the early 5c indexer options on the early vertical machines. they use the same control for both vertical and horizontal. if I get time this evening I'll see if I have notes on it.
  15. #115
    Dec 2018
    Arizona
    115
    7
    Thanks!
  16. #116
    Jun 2019
    Maryland
    432
    72
    look at parameters 462 to 497 and see if anything looks odd. also If you don't have a original parameter list. call haas and they will email a list to compare it to what you have.
  17. #117
    Dec 2018
    Arizona
    115
    7
    I emailed haas for the parameter list I couldn't find their phone line. I don't see any settings in that range.
    The jog handle knobs have broken off on the pendant. but I should be able to find some encoders that will work. also this was caked in a black layer of dried coolant, and the cable inside was unplugged.
  18. #118
    Jun 2019
    Maryland
    432
    72
    Haas direct phone number. 8052781800. that should be a 4 to 6 position selector switch. being you don't have 5th and 6th axis a 4 position should work fine.
  19. #119
    Jun 2019
    Maryland
    432
    72
    any luck getting the parameter list?
  20. #120
    Dec 2018
    Arizona
    115
    7
    Not looking good, they said on a machine that old they don't have the factory parameters. Im thinking If I could find someone who has one they could take some pictures of all of the parameter pages.
    There must be some sort of documentation on the default settings.
