Haas st lathe issues - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #41
    Feb 2009
    Merrimac, Massachusetts
    695
    627
    222
    Quote Originally Posted by IronReb View Post
    Just incase it isn't known, those centering pins are on a cam. Loosen the screw in the middle and rotate to compensate misalignment on the tool block.
    You know after reading this it jogged my memory........... I just walked out to the lathe and popped 2 blocks off of the three that haven't moved in three years(ish). The cams are all there and set...... I left them out at first after I was told to ditch them. I must have put them back in after I re-aligned the turret when I was told they were cams (I forgot about that ). That was three years ago......
    so my bitching has been for nothing...... Oh well I guess you can't remember everything.
    The cams that are out are for a couple custom blocks that come on and off and move position.
    The boot print always annoyed me more anyway
    Jason,
  2. Likes IronReb liked this post
  3. #42
    Aug 2019
    UNITED KINGDOM
    Did you get to the bottom of your problems with your lathe? Just bought a Haas and I'm having the same problems. Just need to know if there's something wrong with my particular machine or if this is what Haas machines are like. I spoke to someone today with a similar size machine and he said there was definitely something wrong, but Haas haven't been able to fix it yet or give me any answers.
  4. #43
    Jan 2008
    Florida
    6
    Patrickwatts,
    What year is your machine with the same problem. I am getting delivered a brand new ST-25Y and it has different castings and arrangement than the OP's machine.
