VF3 refusing to start - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
  1. #41
    Jun 2019
    Maryland
    250
    37
    on parameter 57 disable g.b should be a 1 like you have. I'd leave the invert gearbox alone as once you disable it I cant see how it comes into play ? I guess you could try that 1 either way. but on 57 that should be a 1 like you have it.
  2. #42
    Oct 2019
    UNITED KINGDOM
    26
    Thanks guys for all your help you've been great, much appreciated. We've adjusted those parameters and now set to 1000rpm it is doing about 350 and showing 200% load. The spindle spins freely by hand. Set to 200rpm and it is doing 200 load goes to 112%? I'm thinking there must be other spurious parameters? No alarms showing.
    Drew
  3. #43
    Jun 2019
    Maryland
    250
    37
    are you sure you don't have a gearbox? and are you certain about the delta/ wye. I had a similar problem once . and it was from someone who had a gearbox had disabled it in low gear and told the machine that it didn't have a gearbox.
  4. #44
    Oct 2019
    UNITED KINGDOM
    26
    Quote Originally Posted by Hoss710 View Post
    Hi Hoss
    I've attached a picture from the electric cabinet that says it has the Delta/Wye. Where it says gearbox it was originally circled then tipexed out.
    Drew
  5. #45
    Jun 2019
    Maryland
    250
    37
    it of curiosity. what software is in the machine?
  6. #46
    Jun 2019
    Maryland
    250
    37
    tou should see it during boot up mode. or under diagnostics, then page down a few pages.
  7. #47
    Oct 2019
    UNITED KINGDOM
    26
    It's M11.13F
  8. #48
    Jun 2019
    Maryland
    250
    37
    did you compare the software number to thev1 written in the back of the cabinet? I could be wrong, but that may have had a software upgrade. if so some of the other parameters values will change. if they are different, you will have to call Haas in CA . and they can run a scan and tell you what values have changed, and what they will be now.
  9. #49
    Oct 2019
    UNITED KINGDOM
    26
    Quick update
    After complaining about the last visit from a Haas engineer that told us the gears weren't changing, it hasn't got a gearbox!they are sending us another engineer tomorrow. Hopefully this one will know what he's looking at.
  10. #50
    Oct 2019
    82
    8
    Quote Originally Posted by Drewdt3 View Post
    Quick update
    YIKES! Talent pool seems a little shallow at Haas.
  11. #51
    Oct 2019
    UNITED KINGDOM
    26
    SUCCESS! 2nd HAAS engineer knew his stuff. The problem was when we re-entered the model 8nstead of just VF3 we should have inserted VF3D. Small problem with relays stopping the tool changer moving correctly, had some on his van. All now working spot on and already made chips. Thanks everyone for your help in trying to sort this out.
    Drew
  12. Likes Milland, kustomizer liked this post
