Help identifying this tool
Results 1 to 7 of 7
    Sep 2020
    Wisconsin
    Default Help identifying this tool
    image.jpgI’m not sure where I got these but I have no idea what they are. Markings are Madison and then some engraved measurements and maybe stock number. Can someone tell me what these are? Thanks
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,204
    2381
    1316
    Pictures would help.
    Sep 2020
    Wisconsin
    Sorry I’m new on here and trying to figure out how to do that.
    Sep 2020
    Wisconsin
    image.jpghere it is
    Oct 2010
    Oregon
    5,456
    5093
    2035
    That looks like an adjustable "reamer" or "counterbore" cutter, intended to be driven by a arbor with a slot through it. The 4.166 scribed on it is probably the diameter of the job it was last adjusted to fit. The notches on one edge engage with a small lug on the driving arbor to keep it roughly centered with moving the tool in and out of the hole, but in operation it's supposed to be self-centering.
    Sep 2020
    Wisconsin
    Thanks for the info, I’ll research it that way.
    Oct 2010
    Oregon
    5,456
    5093
    2035
    Found a couple of photos of a large-ish Madison reamer arbor on eBay. Notice the undercut in the slot. There's a matching thicker section on the reamer cutter, and that retains the cutter when withdrawing the tool from the hole.
    While you can think of these as counterbore cutters, they are not intended for massive metal removal. I found some suggestions that the leading edge should have a taper of 1/32" or 1/16" at 45 or 30 degrees, depending on material hardness, and that taper represents the upper limit on how much the tools is expected to take off the radius.
    The tool you show in your photos is obviously a slightly different style, but it's the same general type of tool.
    Attached Thumbnails Attached Thumbnails madison-reamer-arbor.jpg   madison-reamer-arbor-2.jpg
  8. Likes dalmatiangirl61 liked this post
