Hyster...need advice.
Likes Likes:  0
Results 1 to 3 of 3
    Sep 2017
    South Carolina
    Default Hyster...need advice.
    I just bought a hyster rc150 and it's got a hydraulic pump that leaks pretty bad. Does anyone know if they make parts or who has reconditioned ones. I put the numbers I found and haven't had too much luck. It's a permco 02-0592 and another number is tsz 0575. And I also have absolutely no brakes and not sure the best way to go about checking. I'm not even sure what brake fluid to use.
    Jul 2009
    Peoria, IL
    11,714
    51
    8973
    Most older forklifts have dirt simple hydraulic pumps. A good pump shop can rebuild yours.
    Hyster can get you brake parts. There might even be aftermarket parts available. I always just used plain old DOT 3 brake fluid.
    Sep 2017
    South Carolina
    I was toying with trying to get the parts and do it myself. I don't know what numbers to punch in. It's probably a newer number that replaces these numbers I'm guessing.
