Orbital TIG Welding internal discoloration issue
Likes Likes:  0
Results 1 to 3 of 3
    Dec 2018
    INDIA
    Default Orbital TIG Welding internal discoloration issue
    Material AISI316, outer tube diameter 8mm 0.8mm thick. Purge gas Argon 99.995 purity. However found discoloration at internal surface one direction. Strange to know happening only less than 8mm tube. We used same machine for diameter 10mm 0.8 thickness and observed no any discoloration. Kindly suggest any value. Purge injector is made of Mild steel. Is that may be a problem?
    Langley, B.C.
    1,685
    341
    983
    How close is the purge injector to the actual weld? The only way I can see it being an issue is if it's close enough to
    the weld that it gets hot and starts off-gassing or breaking down. Only other thing I can think of is that the smaller
    diameter tube may need a bit higher gas flow. On a larger tube 2 mil is nothing but at that diameter you're talking
    about roughly a 25 per cent reduction...
    Aug 2010
    Minnesota
    1,987
    150
    1467
