Posting test Landis grinder
Results 1 to 5 of 5
    Nov 2002
    Western ,Oh ,usa
    515
    273
    30
    Default Posting test Landis grinder
    Whatta grinder !
    Attached Thumbnails Attached Thumbnails mello-grinder.jpg   landis-ch-10x36-grinder.jpg
  2. Likes michiganbuck liked this post
  3. #2
    Nov 2002
    Western ,Oh ,usa
    515
    273
    30
    This is the workhead,,,,,the hole on the right and the dog are somehow used to make the spindle dead yet outer rotates ?
    Nov 2002
    Western ,Oh ,usa
    515
    273
    30
    Jul 2004
    Houston, TX USA
    31,025
    My B&S uses a knob equipped shot pin. Out the spindle is "live". in it is "dead", but of course the dog driver rotates so you can grind work between a set of "dead" centers. Typical of UNIVERSAL cylindrical grinders.
    "live" for when you want to use the spindle mounted grinding chuck
    Thumbnail is a set up using the chuck
    Quote Originally Posted by lalatheman View Post
    Mar 2009
    Brunswick Oh USA
    4,655
    5300
    2783
    That's correct. I had one like that (12 x 26), but older. There should be a 5/16 setscrew in the hole shown. When engaged the inner and outer turn as one. When you take the screw out a pin should follow. I always rotated the head so the hole was down. The pin would fall out. Now the center is stationary to where you can install your center. On the rotating outer are tapped holes to hold you dogs. If you don't have a center and it's not a Morse taper then it's probably a Brown & Sharpe #7. This is from memory and also an older machine. Good luck.
