How do I do a global search?
Likes Likes:  0
Results 1 to 6 of 6
    Sep 2006
    Rio Vista, CA
    31
    Post
    Is there a way to do a global search (i.e. across all the forums)? I've read the FAQ and hints, but have found no answer. The search dialog requires me to choose a forum, so if I want to search the whole board, I must repeat the search (up to) 29 times. Is there a way around this? Thanks!
    Jan 2006
    louisianna
    55
    Post
    http://www.practicalmachinist.com/ub...ic/34/532.html
    This might help,5 posts down. good luck.
    Sep 2006
    Rio Vista, CA
    31
    Post
    That is a good trick and I will use it. Not as clean as if the board had its own global search function, but a good workaround. Thank you for pointing it out, mazak.
    Best regards,
    Randy
    Feb 2003
    Toronto, ON
    1,284
    16
    If you click Search > Advanced Search, the default is "Search All Open Forums" and a check mark is set at [ v ] Also search in child forums.
    Isn't that pretty much a Global search.
    Arno
    Oct 2019
    DENMARK
    6 Tips for finding new suppliers | Sathive sourcing | start for free!
    Here is an interesting insight about what qualities to look for when searching for a supplier globally.
    Oct 2005
    15,129
    Quote Originally Posted by Anders Svendsen View Post
    Wow..."Denmark Spam".....much tastier from the "Happiest People"....
