gmach10
Hot Rolled
- Dec 27, 2008
- N.E. Illinois
It's just what the title says. Replaced the half nuts and I'm wondering where to start the adjustment from. There's a set screw in the saddle that acts as a stop for the top half nut. The lower nut has a 1/4 - 20 socket head cap screw and a 1/4 - 20 set screw. The cap screw screws into a block that slides within the lower half nut. The block contains the pin that rides in the cam. The set screw threads into the half nut and acts as an adjustment for the block within the half nut. After assembled the centerline of the nut halves is to high, lower half is engaged in the lead screw in the released position. The original nuts were worn on the threads and the engagement lever would not stop when pushed down. Starting position was about 11 o'clock and when engaged the handle could be pushed to the 6 o'clock position and beyond. Is there some sort "hard stop"? I've heard that the only stop is the nut bottoming out on the root of the lead screw thread. I'll take another shot at this tomorrow and let you know how I made out. If anyone has any experience with these I'm all ears.
