Accu-finish sharpener
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,503
    439
    2048
    Default Accu-finish sharpener
    I was thinking of making something like the Glendo Accu-Finish grinder..
    If I attach an 8" 600 grit diamond lapping wheel US 200mm 8" Diamond Flat LAP Wheel Grit 600 Lapidary Jewelry Grinding Polishing | eBay to it along with a rest... I think it should work OK..
  2. Likes Pete F liked this post
  3. #2
    Aug 2005
    Tucson AZ
    6,255
    9271
    2930
    That is a grinding wheel not a lap. Three things to worry about here.
    1. They don't know lapping from grinding
    2. The diamond concentration is "perfectly high". That's not exactly an industry standard term.
    3. There is no recourse on a chinese manufacturer.
  4. Likes aerodark, Mcgyver liked this post
  5. #3
    Sep 2002
    Lawrenceville GA USA
    6,175
    697
    1315
    I doubt that motor will handle the load once you put a tool to it....but if it does work then hop to it!!!
    Charles
  6. #4
    Mar 2005
    5,503
    439
    2048
    Quote Originally Posted by tdmidget View Post
    1. I am not really sure there is a difference.. AFAIK lapping just means low speed grinding with very fine abrasives.. it is still a grinding process..
    2. For the price I doubt there is a massive concentration of diamond material, but enough for limited use.. Thick diamond wheels from moretrusted manufacturers are big $$$.. but proce of diamond has obviously dropped a lot over the years as synthetic diamonds become easier to make..
    Quote Originally Posted by CBlair View Post
    Charles
    The motor is 260 watts or 1/3hp @ 145rpm... Big enough for a lap.. The motor/gearbox is US built out of a microfiche machine..
  7. #5
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Sweet as Bro!
    I thought 600 might be a too coarse for lapping. I have a wheel, but I'm not sure what grit it is off the top of my head, not what I'd think was coarse anyway, and it just eats carbide! Could you try it with a cast iron on other sort of lap with impregnated diamonds from paste?
  8. #6
    Jul 2005
    Cottage Grove, MN 55016
    7,567
    4085
    4518
    Bob the host of the Kansas City class bought a set of those types of wheels. 200, 600, 1200 and i think 2000 grit for $65.00 on ebay or something like that and he bought a Chinese slow speed grinder from the green bear store. It had a lightweight wheel on it and he put the lapping disk up against the side of it and it worked slick. That little motor does look a bit small, but hell nothing ventured nothing gained. in the Swedish class we made an arbor and put a Glendo 1200 grit wheel in his lathe and made a wood block cut at a 5 deg angle. I lousy picture but it's attached to the right side of the green machine and has a round tool rest. ( having a hard time seeing the pictures as I had one eye fixed and one eye is getting fixed next Monday (Cataracts). Rich
  9. #7
    Sep 2006
    Stillwater, Oklahoma
    1,249
    81
    647
    I've got the motor base from an otherwise worn out food processor I've been saving for just such an experiment. It's relatively low speed - I think I clocked it at roughly 600 rpm and by weight seems hefty enough. I have some friends who are interested in scraping but are retired on disability and low incomes so if there are low cost ways to help them get useable tool sharpeners it's a good contribution.
  10. Likes Richard King liked this post
  11. #8
    Jul 2005
    7,567
    4085
    4518
    Good Idea TG...I bet one could find one of those old 2 beater cake mixers at a Salvation Army store or Good Will and buy a slow motor for cheap and rig up something...:-)
  12. #9
    Nov 2013
    Eastern Massachusetts, USA
    3,858
    4236
    4067
    Please post pictures of the finished rig and some feedback as to how well it works.
  13. #10
    Aug 2005
    Toronto
    4,729
    3141
    3561
    Quote Originally Posted by RC99 View Post
    they're quite different. Lapping is abrasive cutting where the grit is embedded in a non-sacrificial material - ie cast iron - and very often of the geometrical accuracy of the lap is important in determining the out come. For example a lapping plate or cylindrical internal lap. Grinding on the other had has the abrasive bonded together and is sacrificial.
    viewing the action in the context of sharpening the end of the scraper, I can see how the ops might look similar so it might seem like splitting hairs, but both processes get used so many different ways, it would be a mistake to start thinking of them as the same.
    since its posted in scraping, the intended use is carbide scraper sharpening? what do you see as the advantage of the slow rpm?
  14. Likes tdmidget liked this post
  15. #11
    Sep 2006
    1,249
    81
    647
    The hook I've always had for distinguishing grinding and lapping is that lapping uses a free abrasive. The most dramatic mental pictures are the free abrasive machining (FAM) setups with a large rotating plate, several smaller rings holding a group of parts, and pressure platse on top of the the parts in the restraining rings. My sense was that the abrasive slurry was constantly recirculated as it worked its way out and was slung off the edge of the plate.
    The claims for the process are interesting too. They can produce very flat surfaces (if the lower plate is maintained) and very parallel surfaces between the top and bottom if desired. To get all the parts in the ring parallel, they're just randomly rearranged a time or two so the net effect is like surface plate flattening by successive comparisons and rotation. You can imagine that with random errors in thickness initially, the pressure plate over the whole group will wind up producing a wedge shaped assembly. By moving individual parts around, tall and short get averaged out to parallel.
  16. #12
    Aug 2005
    Toronto
    4,729
    3141
    3561
    Quote Originally Posted by TGTool View Post
    free abrasive lapping is a subset, cutting can be by both embedded abrasive and rolling abrasive....buts a just a (smallish?) subset. Lapping as you use for sharpening a scraper has the abrasive embedded in the lap (which becomes the cutting tool) The lap itself remains largely untouched (unlike with the free abrasive use you described).
    I don't mean to sound like gods gift to lapping, I've done some done flat and and a bunch of internal cylindrical, but the greater part of my knowledge comes from "Handbook of lapping polishing"...I'm quite prepared to be wrong in the face of superior knowledge
  17. #13
    Nov 2013
    3,858
    4236
    4067
    Quite a few decades back I worked at a company that made equipment for spraying hot melt glue. The gear type pumps used all metal to metal seals. The pump parts were all surface ground as matched sets and then hand lapped using a cast iron lap. The rotating parts were lapped just a little bit more time than the pump body for clearance.
    Pressures were extremely high as the molten glue was pumped through steel braided hose to the nozzles. When new hoses were required we crimped the fittings on with 4 segment tapered dies using a rig with a bottle jack for power. The worst part of a rebuild was removing the hardened and baked on glue.
  18. #14
    Mar 2005
    5,503
    439
    2048
    This feels like the Spanish Inquisition at times..
  19. Likes AHC, Richard King liked this post
  20. #15
    Sep 2006
    1,249
    81
    647
    I don't expect anyone here intends to be abrasive but we've all been lapping up bits of knowledge for so long we're anxious to polish any bits we think we have. The adamantine opinions may come across a little rough but after a series of posts it usually sorts to the nitty gritty.
    I will stick to my loose abrasive opinion though, whether it's embedded first or simply embeds itself in the process of introducing the lap, the workpiece, and the abrasive to each other. Even when not intentionally embedded first the usual advice has been to use a softer material for the lap so that the abrasive embeds there and scours the workpiece. Finished size and shape may be a function of both the lap's accuracy and/or of the action between the lap and workpiece if they're stroked as one might in honing. So one case might be a shape used to lap a mold cavity where the shape of the lap is transferred to the work. Another might be the small hole laps such as these just down the page here where only a portion of the lap is the desired size of the hole and it must be worked along the length of the workpiece.
    And also it may be a matter of nomenclature getting us confused or of course I could simply be wrong about all of this.
  21. Likes CBlair liked this post
  22. #16
    Jun 2001
    St Louis
    17,807
    1767
    2954
    Dunno about the semantics.....
    But the original Accu-Finish works extremely well. If the shop-made one is anything lik it, it will work very well also.
    The combination of slow speed and water-coolant makes the diamond wheels OK for steel as well as carbide.
  23. Likes Richard King liked this post
  24. #17
    Feb 2008
    Utah
    2,881
    Partial Gratuitous Thread Hijack Warning!
    Is the secret formula that they sell for making coolant hooey? Can kerosene, synthetic coolant, other be used more economically with good results?
  25. #18
    Jun 2001
    St Louis
    17,807
    1767
    2954
    Quote Originally Posted by aerodark View Post
    I just put a tiny amount of detergent in water and go with it. Been doing that for years, and it works fine. No magic. The water has to "wet" the wheel, which the detergent makes happen.
  26. #19
    Aug 2005
    Toronto
    4,729
    3141
    3561
    haha, where are are those red hot pokers when you need them
  27. #20
    Mar 2007
    Milwaukee
    408
    344
    186
    Quote Originally Posted by JST View Post
    Windex or any glass cleaner works too. It also cleans up Cannode spoting ink.
