Advice needed - bearings for old lapidary saw
Results 1 to 5 of 5
    Mar 2020
    Default Advice needed - bearings for old lapidary saw
    Hi,
    I am restoring an old lapidary saw. It has two bearings on the arbor shaft and I know that one of them needs to be replaced, the other one is fine.
    I am looking for help with 2 things:
    1) I haven't done this before and I am having trouble getting the bearing to come of the shaft. It has eccentric locking collar and I removed the set screw already. I tried inserting a screw driver into the other hole and tapping it in the other way than the way the shaft usually rotates in. It doesn't budge. Any tips on how to get it off or maybe even links to some good videos explaining how to get a bearing like that of the shaft?
    2) I am trying to figure out what bearing to replace it with. The collar has this on it "204-012 SKF MADE IN USA". I was able to find these on ebay but the pictures look a bit different and there are several sub types. Do the bearings need to be exactly the same or what are the important parameters to look at?
    This is a picture of the bearings and the shaft.
    Thank you, I am very new to this!
    Tereza.
    Jul 2005
    Cottage Grove, MN 55016
    7,725
    4145
    4607
    No one has answered you in 4 days. I figured someone would have by now. That's a Pillow Block Bearing Those collars are pressed on and not screwed on.
    YouTube
    Pillow Block Bearings - Mounted Bearings and Inserts - Grainger Industrial Supply
  3. Likes michiganbuck liked this post
    Jun 2012
    Michigan
    10,418
    3549
    3715
    Plus screw driver tapping does not give much pressure. With the bearing jackets off a decent puller would be better..set so it pulls on the minor diameter of the bearing so to not harm the good one.
    I like to clean up a shaft with a fine flat file so just the bugs are removed down to witness the original surface, not take stock all around like emery does..
    Mar 2009
    Eureka, CA
    3,808
    779
    1352
    In regards to the eccentric lock...it will lock in either direction so just assuming it was locked in the opposite direction of shaft rotation is not valid, it could be locked either way. Tapping will not get results, you need a serious hammer and a good punch and you must hold your mouth just right or the thing won't budge. Smack the heck out of it and it'll come off.
    Stuart
  6. Likes Illinoyance liked this post
  7. #5
    Dec 2010
    georgia, usa
    91
    28
    19
    I personally prefer cast iron pillow block bearings vs stamped steel. Replace with whatever is cheap and available to you.
