Bearing Help - which Lube?
Likes Likes:  0
Results 1 to 8 of 8
    Apr 2019
    New Jersey
    80
    8
    Default Bearing Help - which Lube?
    Hi All,
    I am helping a friend work out details on a 1970’s~ Martin shaper. The machine uses FAG 6212-TB-P5 oil bath bearings and the machine manufacturer requests the user to use their special oil....only available via shipping from Germany.
    I can’t find any specs on what lube to use, so any insights would be greatly appreciated.
    Thank you!
    Brian
    Jul 2004
    Houston, TX USA
    30,444
    Thousands of "ball type" bearings in machine tools thrive on such as Mobil DTE Heavy Medium (ISO 68), Medium (ISO 46) and Light (ISO 32) - depending on operating speeds
    Apr 2019
    New Jersey
    80
    8
    Hi John,
    Thanks for the response, sounds like an excellent choice. The operating RPM is 9000. I presume lighter fit higher speeds, am I correct?
    Jul 2004
    Houston, TX USA
    30,444
    That is on up there - might go for such as Mobil Velocite 6 which is ISO 10. Need a way to check running temperature of oil bath - even if it is just the palm of your hand on the case.
    I'd guess that if you cannot do a hands-on for any length of time (due to HOT) that you really do need the stuff from the Father Land
    Apr 2006
    Manchester, England
    8,548
    1315
    5496
    9,000 rpm on a shaper ?
    Regards Tyrone.
    Apr 2019
    New Jersey
    80
    8
    A wood shaper, Tyrone.
    Thanks, John!
    Jul 2006
    Hillsboro, New Hampshire
    8,218
    1938
    5797
    Quote Originally Posted by BHolcombe View Post
    Thanks, John!
    Are the bearings literally just in a pool of oil? If so, that must generate a lot of heat during operation at that speed.
    Apr 2019
    New Jersey
    80
    8
    No, they have a pump that circulates the oil through a coil and reservoir.
