bmikkalson
Hot Rolled
- Jan 20, 2010
- St, Paul MN
Have a older drill press that has lots of slop. Tapper on the quill is .020 and the cast iron sleeve is wore just as much. Here is what I am thinking,
Turn the old quill down ( non chrome finish), use some kind of bearing build up epoxy pour to fit.
Turn down quill and install brass sleeves in body.
cut a cap in body and try to squeeze the head bore together.
Take 3 brass set scress and apply pressure around the bore, so that the quill will ride on 3 contact point.
Throw the hunk of shit away..
What you guys think?
