Biax 7EL part dimension needed
Results 1 to 10 of 10
    May 2006
    Seattle
    1,964
    38
    377
    Default Biax 7EL part dimension needed
    My 7EL's leather strap was gone when I got it. So is the forward strap attachment piece.
    The latter part (the forward strap attachment) is apparently a sheet metal part that is captured by a black hex cap nut. You can see the black hex cap nut in this picture:
    So the attachment probably has a clearance hole for 25mm threads in it. At the other end of that missing attachment piece, where the strap attaches, should be a slot about 5/8" wide and 1/8" tall. The narrow part of the leather strap goes through that slot, folds, and comes back to be riveted. The strap belts to the other attachment point on top of the machine.
    I need the dimension between the 25mm hole and the 1/8" slot in order to make a new front strap attachment point part. If you can post this dimension, it would be most welcome.
    metalmagpie
    Jul 2007
    UNITED KINGDOM
    4,930
    2729
    2404
    Just make one to fit. It doesn't have to be identical to the original in order to hold the strap.
    Jul 2005
    Cottage Grove, MN 55016
    7,725
    4145
    4607
    contact Ed Dyjak who owns ESDyjak in Milford MI [email protected] as he sells parts from old scrap machines and you can buy straps leather straps that are far superior then OEM and 1/2 price from Bob [email protected]
    If Ed doesn't have anything many use wire wrapped around the threads to hols the strap.
    Sep 2006
    Stillwater, Oklahoma
    1,389
    103
    751
    I haven't separated this from the strap because it's riveted, but you can see the design. There's a tubular roller just visible to reduce chafing on the strap, and the upper portion where the strap attaches has a bend of about 45 degrees forward for additional clearance. The slot at that point is about .80" or about 20mm.
    May 2006
    Seattle
    1,964
    38
    377
    Quote Originally Posted by TGTool View Post
    That's just about what I'd figured from looking at pictures on the Web. But none show it nearly as clearly as yours.
    Wonder how to add a tube roller to that part.
    metalmagpie
    Sep 2006
    1,389
    103
    751
    Quote Originally Posted by metalmagpie View Post
    metalmagpie
    The traditional way would have been to form the roll, mostly closed and then finish in assembly. It doesn't have to be able to rotate. If you want to know how a roll might be formed I've got something in a book or could just sketch the fixture. For my money I'd just braze a rod on the end, You could fab the flat part with an open end and slot the ends of the rod for a shear joint.
    You're a machinist, use what makes most sense to you.
  7. Likes Paolo_MD liked this post
    May 2006
    Seattle
    1,964
    38
    377
    In the end I just made one. I'm no leather worker, but I think it's serviceable.
    See: - metalmagpie
  9. Likes Peter., TGTool, Jersey John, Mark Rand liked this post
  10. #8
    Sep 2006
    1,389
    103
    751
    That looks good enough, and if it does the job that's all you need.
  11. #9
    May 2015
    UNITED KINGDOM
    1,270
    376
    358
    I needed one too for my 8EL ... first one didn't work as the leather I bought was too soft and strechy ...
    Second one I made with 3/4mm leather and it was more than "Man enough" to cope with the scraper weight
    John
  12. #10
    May 2006
    Seattle
    1,964
    38
    377
    Here's my scraper with the strap fitted. It seems to be about right on my hand.
