Hello, I’ve been lurking for a while and this is my first post.
I’m recondioning a 1959 Rockwell 11x36, it has seen a easy life, used as a prop for Hollywood and turning only wood. There was so much wood pulp and sap everywhere and zero metal chips where you would expect to see them.
On the quick change gear box I have torn apart for cleaning and painting. I noticed the oil holes for the brass bearings are blind, meaning the bearings do not have any oil passages or holes to flow oil from the oil port cap into the bearings and shafts. So I think I need to drill a little hole for oil to flow. Has anyone seen this before? Is possible mistake from the factory? Or am I missing something.
