blueing (new approach)
Results 1 to 16 of 16
    Feb 2010
    ch
    3,314
    275
    460
    Default blueing (new approach)
    im proposing to use copper sulphate to check taper-fit, lobing and such.
    instead of messing with blue, spreading it with various methods trying to achieve an acceptable distribution, you have a jar with a copper sulphate solution that can be used forever. you dunk the taper in there for a few seconds (depending on temp.) and get an extremely uniform coating of copper. sub micron thickness, if you want. i managed to chip off a piece that i consider very thick and it was 3µ. the copper layer is soft and rubs off easily. what stays behind is a faint glaze, like after using a bronze brush on steel.
  2. Likes michiganbuck liked this post
  3. #2
    Sep 2020
    NAMIBIA
    265
    112
    59
    Nice idea ! Congrats !
    Mar 2005
    Indiana
    6,173
    2166
    2154
    Might work decently, just take care. A small amount of copper sulfate ingestion (get it on your hands, eat a sandwich) can make you very sick or even kill you.
    Sep 2020
    NAMIBIA
    265
    112
    59
    Quote Originally Posted by eKretz View Post
    That's interesting. I was told it's toxic but in the same time I think it is widely used to spray grape vines against some fungus. I wonder now how safe that is.
    Mar 2014
    Michigan
    897
    230
    375
    They use copper sulphate to treat pond algae all over the country. The side effect is it kills all the invertebrates and some amphibians in the water but not the fish.
    Feb 2010
    ch
    3,314
    275
    460
    its used in gardening, thats why it so cheap.
    Jun 2001
    St Louis
    19,330
    2403
    3652
    Interesting thought. Already used prior to scribing lines for layout in the old days.
    Might be a little more difficult to remove for another spotting, and so might build up on areas not rubbed off if repeated.
    Toxicity is not extreme, here is an SDS entry for the lethal doses:
    Animal Toxicity: Dermal LD50 > 8000 mg/kg,Acute oral LD50 (male rats) 472 mg/kg
    That's 8 grams per kg on skin, and about a half gram per kg if ingested. I'd not think anyone is likely to get that by accident if even the least precautions are taken.
    http://msds.mkap.com/DryFertilizer/CopperSulfate.pdf
  9. #8
    Mar 2005
    Indiana
    6,173
    2166
    2154
    Yes doubtful that it will kill you if you don't make the sandwich out of it, but it can make you sick, and is an extreme eye irritant IIRC. I am a little cautious having little children in the house. You could probably eat regular hi spot bluing for a snack with no ill effects... And I think a very thin layer of copper would be much more difficult to see, but do let us know.
    Use as an insecticide or algae killer is in very dilute concentrations - that's a little different than handling the pure full strength form from the bottle.
  10. Likes Orbital77 liked this post
  11. #9
    Sep 2020
    NAMIBIA
    265
    112
    59
    I believe you are right. I remember how quite a few times after eating unwashed grapes on the farm as a child, I would get quite sick. They were sprayed with cooper sulfate but nobody knew it's toxic.
  12. #10
    Feb 2010
    ch
    3,314
    275
    460
    i believe its used as stump-killer, where you spread the granules on the stump.
    anyway, it might even be usefull for scraping/spotting, havent tried that yet. if you really want to remove the haze a peroxide/sufphuric solution will do it fast. of a concentration you can stick your finger into.
    i recently inside-ground some rings, id was 12 mm i believe. i treated them with c.s. and when rubbing on a grinding arbor found "extreme" lobing. "extreme" in view of the fact that film thickness was probably 0.5µ. there were 4 lobes, disposing of the notion that you get uniform pressure from a er collet. now, i dont think this could have been done with blue, lead of thatever else that needs spreading.
  13. #11
    Mar 2005
    Indiana
    6,173
    2166
    2154
    It would be interesting to compare to the gold standard... Black Sharpie!
  14. #12
    Jan 2012
    Florida
    220
    272
    83
    be careful that stuff rust like crazy if you don't treat it (oil)
  15. #13
    Feb 2010
    ch
    3,314
    275
    460
    we dont have "sharpies", but very often a felt pen will not colour a smooth taper very well. at least the ones i know of.
  16. #14
    Mar 2014
    Minnesota
    214
    62
    94
    Just use denatured a!cool instead, no methanol it's poisonous, run it on let dry to a haze, rub on the surface plate to show shiny spots perfect for straight edge finishing
  17. #15
    Sep 2006
    Stillwater, Oklahoma
    1,812
    141
    1059
    Quote Originally Posted by Dresden View Post
    Denatured alcohol is poisonous too FWIW.
  18. #16
    Jun 2001
    St Louis
    19,330
    2403
    3652
    it often is "denatured" by adding methyl alcohol to ethyl.
